bzettner |
Member ![]() ![]() Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region ![]() |
OK, I have a pretty good handle on my ,80 Hp 1.7, EFI. What have some of you 1.7 drivers done to your existing engines and what was the seat of the pants result? Mine is totally stock.
I'm currently thinking of a 1911. Do you run the existing FI? Do you use the stock cam? Would it be better/easier/more bang for the buck to find a decent 2 liter engine and rebuild (2056)? Not that I have a budget, but reliability and fun matter and so does cost. I don't mind a revvy engine. I would enjoy my car "pulling" longer. It signs off rather quickly. I like to "drive" a car rather than rely on gobs of torque and HP (though more than 80 would not be a bad thing). The ability to break the rear end loose with power. Starting the thinking/dreaming process (IMG:style_emoticons/default/chowtime.gif) |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
2056 with D-jet is your best bang for buck choice.
You can use a lot of the 1.7 parts you already have. IMHO. |
Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
I'm having fun with my 1.7, stock D-Jet FI and
1) 12 lb light flywheel = spins up faster 2) high-flow, cold-air intake = sounds louder and faster 3) 4->1 header with 1 5/8" pipes = more power fo real, and sounds louder and faster With a rebuilt suspension, refreshed transaxle, lots of weight reduction, and sticky street tires I am happy. All these mods will stay if and when I actually do something to the engine. Cheapest upgrade is lightness. Removing un-needed or unwanted parts, or upgrading to lighter ones (i.e. smaller battery, smaller starter, composite lids etc). Best purchase was the header. A good header will really wake up any TIV engine. (IMG:style_emoticons/default/beerchug.gif) |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Nah, best bang for the buck is a 2056 with a better cam, Djet etc. 115hp and more torque wakes up a 914 to the car Porsche should've built and sold vs the stock barely 95hp. Gosh, I have had mine for 10 years and its still a f*cking fast car that shocks people who ride along.
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 962 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
I have one of each. "HAM" built both set of heads. The 2056 has 2.0L heads and the 1911 has 1.8L heads with 2.0 valves , both have HD springs. Mine are both carbed, 44's on the 2056 and 40's on the 1911. All Raby internal parts. Love them both, mostly because of the torque. Keep in mind the difference in the heads is the spark plug location, the tin will be different.
Lo-Fi Version | Time is now: 20th June 2024 - 05:31 AM |
