Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Never mind. Thanks Jim!! I found new hose in the Home Depot Garden department.
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,332 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
If it doesn't have to be original OEM hose, Home Depot sells Becker irrigation hose that both looks the same and is the same size. Usually in or around the garden section
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
This yes? PM sent
Attached image(s) ![]() |
Steve |
If it doesn't have to be original OEM hose, Home Depot sells Becker irrigation hose that both looks the same and is the same size. Usually in or around the garden section Thanks Jim!! I will check the irrigation hose at Home depot. Sorry guys!! I will report back after my trip to Home Depot tomorrow. |
jim_hoyland |
Steve, I was at the HD today; they still carry the ribbed drain hose, just not Beckett brand. It's in the garden area; look for the water-features ( pumps, hose, etc). It was on a low shelf..
Attached image(s) ![]() ![]() |
Steve |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:22 PM |
