PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,825 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
When I installed the front and back suspension, I just snugged all the bolts. Now I want to torque them all down and can't find my book with the ratings.
rmdinmd |
Member ![]() ![]() Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States ![]() ![]() |
rear in ft lbs
spring strut bottom 72-87 top 36-43 bushing in piston rod 11-14 castellated hub nut 217-253 universa joint on flange 31 control arm bearing\body 50 control arm bearing\control arm 108 bearing cap 18 same for stabilizer body front suspension strut\ball joint bolt 47 support bracket 58 support bracket\body allen screw 34 control arm bracket cap 33 control arm forward bearing 34 ball joint\control arm 180 (lubricated threads) wheel bolt 108 hope this helps (IMG:style_emoticons/default/smile.gif) |
PanelBilly |
thanks
rmdinmd |
glad to be able to help (IMG:style_emoticons/default/piratenanner.gif)
boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
How does one achieve ("castellated hub nut 217-253") that many foot lbs? Air tools only? Or lots of patience?
rmdinmd |
1/2 inch breaker bar, body weight and best guess. (IMG:style_emoticons/default/biggrin.gif)
18" breaker bar standing on it; my weight is 200 lbs times 1.5 = 300 ft lbs. my torque wrench goes up to 250 ft lbs. my buddies 356 required about 300 ft lbs on his rear wheel hubs per his mechanic so we did the bar and body weight trick as suggested by the mechanic. seems to have worked, no more gear oil leakage. I was nervous about doing it but Al said to go ahead so we did. |
Lo-Fi Version | Time is now: 28th June 2024 - 08:10 PM |
