early 1.7 no start, FI troubles |
matt5596 |
Mar 20 2014, 11:16 AM
Member Group: Members Posts: 102 Joined: 28-September 11 From: Norris, TN Member No.: 13,619 Region Association: South East States |
'71 1.7 with original FI, won't start.
Distributor doesn't appear to have injector trigger points (i have only one wire coming off the distributor). What else should I check? (IMG:style_emoticons/default/confused24.gif) |
Spoke |
Mar 20 2014, 11:31 AM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Is this no-start a new issue or has the engine never ran for you before?
Are you sure the dizzy doesn't have trigger points? How about the connector on the dizzy for the trigger points? Where's the connector for the trigger points? Have you located that on the engine? Without the trigger points you will have no fuel in the injectors. |
matt5596 |
Mar 20 2014, 11:39 AM
It was running before changing out all the fuel lines. Maybe i knocked something loose.
I only assumed no trigger points since i saw only one wire coming off the distributor. |
Spoke |
Mar 20 2014, 11:48 AM
Should be a connector coming off the base of the dizzy. If not, find the pigtail with 3 or 4 wires that connects to it and reconnect it.
914_teener |
Mar 20 2014, 01:01 PM
914 Guru Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The connector is usually on the backside of the dizzy and comes from the FI harness......gotta stick your head in there.
TheCabinetmaker |
Mar 20 2014, 01:30 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You got the supply and return lines crossed perhaps.
Dave_Darling |
Mar 20 2014, 03:32 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Perhaps that. Also check all of the electrical plugs in the engine bay. It's not that hard to bump one and disconnect it. Every once in a while, you may be able to move it enough to disconnect the connector electrically, but not enough for the plug to be flopping around loose...
--DD |
Lo-Fi Version | Time is now: 25th June 2024 - 11:06 PM |
