Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Out for a drive in the sun. Top off. Zipping along. Shift gears. POP (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Who wants to help fix a broken clutch tube? Thank goodness I had a pair of vice grips in the car so I could get home. |
poorsche914 |
T4 Supercharged ![]() ![]() ![]() ![]() Group: Members Posts: 3,093 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States ![]() |
Out for a drive in the sun. Top off. Zipping along. Shift gears. POP (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Who wants to help fix a broken clutch tube? Thank goodness I had a pair of vice grips in the car so I could get home. I used a pair of vise grips on a broken clutch tube. Twenty years later it was still doing its job (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/driving.gif) |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
This hardware store clamp and angle iron worked for about 8 years until I finally pulled the engine and fixed properly.
![]() Here's the permanent repair with 2 layers of 14 ga steel. ![]() |
Mblizzard |
Yep I am looking at a temp repair for a while. But will be doing it right at so,e point. You bringing the welder from PA?
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
If you bring it over the mountain to Asheville some weekend I could weld that up for ya. (IMG:style_emoticons/default/welder.gif)
Mblizzard |
If you bring it over the mountain to Asheville some weekend I could weld that up for ya. (IMG:style_emoticons/default/welder.gif) May have to do that as my wife has so far been supportive but draws the line at me buying a welder. (IMG:style_emoticons/default/confused24.gif) Ok so there are a few unexplained fires in my history but I don't think that they are relevant. |
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
Your wife is wise, very wise! (IMG:style_emoticons/default/dry.gif)
Mblizzard |
My wife says welders are like pickup trucks. You don't need to own one all the time, but it is good to know some on who has a truck just in case. Faulty logic if you ask me! I have always owned a pickup so I should have a welder also |
Lo-Fi Version | Time is now: 26th June 2024 - 10:31 AM |
