Seabird |
Member ![]() ![]() Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States ![]() |
Hey everyone. I bought this 914 2.0L back in November and have been slowly preparing it for the track. The underside was pretty messy with oil when I got it. I got the impression that the push rod tubes were the source of the oil so I decided to go ahead and replace them, their o-ring seals, and adjust the valves. That project went well. I was doing other engine maintenance (ignition, exhaust, etc...) items and have now finally gotten around to being able to crank the engine up.
When I got is started I noticed there is still a bit of an oil leak coming from the 1-2 bank. Initially I blamed my install of the push rod tubes. After a close inspection I noticed the oil is coming from higher above. I took a few pics last night after running the engine for 10 min or so. It was not easy to photograph because of lighting. The red circles show where the oil is. The bottom picture shows the push rod tubes and the seals. (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-16683-1395409043.1.jpg) Thoughts? |
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
Oil Pressure Sending Unit can leak from above, oil cooling unit seals.....
There are so many places a IV engine can leak. Someone jokey said, they will stop leaking when they run out of oil! (IMG:style_emoticons/default/smile.gif) |
Seabird |
Oil Pressure Sending Unit can leak from above, oil cooling unit seals..... There are so many places a IV engine can leak. Someone jokey said, they will stop leaking when they run out of oil! (IMG:style_emoticons/default/smile.gif) Thanks Jawja. This is one the drivers side so probably not from the cooler and the oil press sender is dry. I would hate to think this is a typical leak and will be a regular source of stress. Miguel |
luskesq |
Member ![]() ![]() Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California ![]() |
Have you checked the bolt going through the thermostat pulley? It goes directly into the case so you might need to sealant on the threads or perhaps it is simply loose.
Keith |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
It looks like the oil is either coming from the cylinder/crankcase interface and migrating to the lowest point on the tin, or from the head/cylinder interface.
In either case, it won't amount to much of a leak. |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
i can't really tell but it could be leaking from where the cylinder heads attache to the case- i know i have this issue and it will eventually be taken care of, but its not bad enough to force me to pull the motor --- yet, because at that point with 140,000 miles, it will for sure mean a full P & C rebuild, heads valves etc, maybe a 2056 upgrade-- just not yet. - anyway thats probably where its coming from but if its not severe, dont worry about it, they all leak some, just keep an eye on the oil level
Seabird |
i can't really tell but it could be leaking from where the cylinder heads attache to the case- i know i have this issue and it will eventually be taken care of, but its not bad enough to force me to pull the motor --- yet, because at that point with 140,000 miles, it will for sure mean a full P & C rebuild, heads valves etc, maybe a 2056 upgrade-- just not yet. - anyway thats probably where its coming from but if its not severe, dont worry about it, they all leak some, just keep an eye on the oil level Thanks everyone. That's kind of what I was afraid of. Thanks for the words of encouragement Chris. Next weekend its going to be looping around Sebring. Nasty oil leak that needs to be corrected before track weekend would have torpedoed my efforts. Miguel |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Oil breather tube return hose right above that spot ? On top of the head there might be a hose to return oil vapers. Hose gets old and crusty and leaks.
ChrisFoley |
... Thanks for the words of encouragement Chris. Next weekend its going to be looping around Sebring. Nasty oil leak that needs to be corrected before track weekend would have torpedoed my efforts. Another possible source is a head stud inside the rocker box. If the seal at the threads or under the washer is compromised oil will gradually migrate to outside the head. That wouldn't be much of a leak either and nothing to get concerned with. Your biggest possible source of oil leakage is going to be the valve cover gasket - if it gets hot enough to grow and move. This is what a cyl. 1/2 valve cover leak looks like from trackside: ![]() I used to use Redlne racing oil which has a very high flashpoint. I never worried about it igniting, although more than once I saw corner workers waving their extinguisher at me. It took a meatball flag or enough smoke in the cockpit to obscure my forward vision to get me off the track. (IMG:style_emoticons/default/evilgrin.gif) |
Seabird |
I used to use Redlne racing oil which has a very high flashpoint. I never worried about it igniting, although more than once I saw corner workers waving their extinguisher at me. It took a meatball flag or enough smoke in the cockpit to obscure my forward vision to get me off the track. (IMG:style_emoticons/default/evilgrin.gif) I can quite find an emoticon that captures my thoughts on this Chris, lol. Maybe (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/piratenanner.gif) Brakes, fluid change, connect my gauges and load it up!! Maybe I'll actually get to corner balance it before next weekend!! |
biosurfer1 |
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California ![]() |
Lo-Fi Version | Time is now: 1st July 2024 - 06:02 AM |
