brake bleeding |
brake bleeding |
hndyhrr |
Mar 31 2014, 10:39 AM
Senior Member Group: Members Posts: 588 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
Today we are going to bleed the brakes. Got any good advice. Just finished replacing struts back and front so had to pull it all off.
Thanks |
type47 |
Mar 31 2014, 10:45 AM
only the standard/obvious:
start with the caliper farthest from the master cylinder work toward closest. I would suggest using a human to pump the brakes; some have trouble with power bleeders; Motive pressure not so much as Minivac suction |
yeahmag |
Mar 31 2014, 03:56 PM
Advanced Member Group: Members Posts: 2,443 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Best money I've spent was on a Motiv. I use it on all my cars/karts including the 914.
rgolia |
Mar 31 2014, 04:46 PM
GeoJoe Group: Members Posts: 716 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
orthobiz |
Apr 2 2014, 07:41 PM
Senior Member Group: Members Posts: 1,757 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
yeahmag |
Apr 2 2014, 09:27 PM
Buy the European one if I remember correctly.
McMark |
Apr 2 2014, 10:28 PM
Install plugs in the master cylinder outlets and pump until bubbles stop coming up into the reservoir and the pedal is 100%, absolutely rock hard. Then add in the lines one at a time and rebleed.
ConeDodger |
Apr 3 2014, 01:53 PM
Apex killer! Group: Members Posts: 23,852 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Install plugs in the master cylinder outlets and pump until bubbles stop coming up into the reservoir and the pedal is 100%, absolutely rock hard. Then add in the lines one at a time and rebleed. (IMG:style_emoticons/default/agree.gif) And if you are going to use the Motiv (and I have one and do use it) always do the old fashioned two person method at least a couple rotations and give that pedal a good stomping! (IMG:style_emoticons/default/evilgrin.gif) |
Lo-Fi Version | Time is now: 26th December 2024 - 09:20 PM |
