boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
I'm looking to add the spacer/extender for my CHTS on 74 2.0L. Car is running great, but has the common "warmup issue" where idle fluctuates wildly between 500(?) and 1200 RPM after the AAR closes. At times, it almost want to die. Once warmed up, perfect idle at 950 RPM.
The spacer/extender should be M10x1.0 female to male. Can it be brass or are the expansion properties of brass too great? Was wondering if anyone has ever located one at a Home Depot or Lowes? |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Brad Mayer - 914 limited
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
VW T3s had 'em.
The Cap'n |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
This is the correct thread to run into the head (10X1.0).
The female thread is 1/8 NPT, but the CHT should thread into that just fine (at least once) according to some that say 1/8NPT is essentially identical to 10X1.0. https://www.pegasusautoracing.com/productde....asp?RecID=1832 |
boxsterfan |
If anybody is interested, I may have found an M10x1.0 female to M10x1.0 male extender for $8.65 (probably plus shipping).
http://www.trico-oilers.com/Adapter-M10x10...m?categoryId=-1 |
Lo-Fi Version | Time is now: 26th June 2024 - 06:40 AM |
