IT'S LOCKED UP!, boohoohoo |
Mr.C |
Jan 11 2005, 06:57 PM
Easy does it Group: Members Posts: 611 Joined: 31-December 02 From: Central Cal Member No.: 61 Region Association: None |
I decided after years of sitting in the garage to get the 911 my dad gave me going again. Well to make a long story short the engine seems to be LOCKED UP, FROZE however you wanna say it, the damn thing won't turn over! I'm so pissed!! (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) DAMN DAMN DAMN and to think I was planning on taking it to the WCC. I can't even see straight I'm so mad. ok ok deep breaths. Nah I still don't feel any better. Well it looks like I'm gonna be pulling the thing down. I am gonna head on down to the book store and pick up whats his faces book from pelican or maybe just get drunk. (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
morgan |
Jan 11 2005, 07:03 PM
Member Group: Members Posts: 310 Joined: 28-March 03 From: milwaukee WI Member No.: 488 |
Dude slow down put rust off oil in all the cylinders and let them soak for some days
then try to hand turn the motor. JM (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) |
SLITS |
Pull the plugs, fill cylinders with diesel fuel (the ones that will hold the liquid), let set for 3 days, then try to turn it.
If you could pull the engine and bolt a bar across the flywheel, you might break it free. |
Mr.C |
Jan 11 2005, 07:09 PM
Thanks for the suggestions. I'm not worried so much about the cost it's just the shock of it all right now.
Mr.C |
Jan 11 2005, 07:10 PM
I guess you could say that's what I get for putting the 914 on hold. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
jwalters |
Jan 11 2005, 07:13 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Yea, I agree, it is prolly just a carbon lock--that happens allot! Take your drain plug out and drain all the fluids from the engine--take out all the sparkplugs and leave them out--and I agree, fill each cylinder one at a time with a good solvent-something that will break up carbon. Purpose of doing one cylinder at a time --when you fill the cylinder with solvent, if it is ok--the solvent will run out and drip out the drain plug.( this may be slow or fast-depending on if your rings are stuck in the grooves and not sealing well) Do this until you find the cylinder (s) that are plugged up--then let the solvent sit for a couple of days--when you can see in the plug opening that it has reduced--fill it again--and gingerly turn the crank a litle at a time in the direction of normal rotation --you may have to bump the breaker bar handle firmly with your hand--don't just bear down on the handle with all your might--BUMP it--this goes along way to freeing things up well--good luck!! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
joea9146 |
Jan 11 2005, 07:29 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
Could also be a Frozen clutch if the Car has been sitting for a While...
jwalters |
Jan 11 2005, 07:31 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Yea, but by simply putting it into neutral and cranking it would rule that out........ |
jwalters |
Jan 11 2005, 07:32 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Seeing as you are not worried about the cost---you could spread some of your wealth my way, and assist in the resurrection of a 1972 teener!!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
nebreitling |
Jan 11 2005, 07:40 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
always a good response!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/drunk.gif) |
spare time toys |
Jan 11 2005, 07:59 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
(IMG:http://www.914world.com/bbs2/html/emoticons/thisthreadisworthlesswithoutpics.gif) Show us the car.
Jake Raby |
Jan 11 2005, 08:27 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Marvel Mystery oil!!
Fill the entire case with it as well as the cylinders. A mix of Marvel and Dexron/ Mercon auto tranny fuid has saved many on this end! The stuff is a mystery! I once saved a VW engine that had been locked for 10 years with the stuff.. Took about 3 weeks of "Pickling" to straighten it out.... As soon as she fires up, take it out and give it hell to free it up :-) |
newdeal2 |
Jan 11 2005, 09:08 PM
Unregistered |
Great stuff...I agree ...use it a lot on my dual stromberghed GT6! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
skline |
Jan 11 2005, 09:24 PM
I use marvel mystery oil in my air tools. Works great.
Mr.C |
Jan 11 2005, 10:49 PM
The car is a Sportomatic and I tried turning it over at the crank. It must of just happened cause I was able to turn it over about six months ago. I've calmed down, home brewed Portuguese wine helps. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Thanks Jake I'll try the mystery shit. Maybe I'll make the WCC after all. If not maybe I'll take the teener. Imagine that a teener at a 914 event. Damn
Oh here is a pic of the POS Attached image(s) |
skline |
Jan 11 2005, 10:54 PM
That looks nice. If you give up, I will be glad to take it off your hands. I could have it running in a week or so I am sure of it. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Mr.C |
Jan 11 2005, 10:56 PM
How about we just race to see who's car hits the road first. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) That took me 3 months of body work to get it that way, and that was hours every day too. I just never finished it up to drive. I think I got burnt out, but just recently was motivated again till this happened. I'm still motivated, but man this sux.
skline |
Jan 11 2005, 11:08 PM
I feel your pain buddy, if you really want to race, you better have it done this week cause mine is on the road this weekend.
Mr.C |
Jan 11 2005, 11:33 PM
I found the problem.
Attached image(s) |
Joe Ricard |
Jan 12 2005, 07:04 AM
Well there you have it Chop sticks (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) You know what sucks is nearly blowing the morning coffee out my nose reading this crazy shit. |
Lo-Fi Version | Time is now: 24th September 2024 - 12:51 PM |
