topdog |
Newbie ![]() Group: Members Posts: 9 Joined: 7-December 13 From: salem, AR Member No.: 16,739 Region Association: None ![]() |
attempting to correct minor up/down movement of steering wheel. po replaced oem wheel with a momo. removed horn button and nut but wheel won't slide up and off. steering shaft looks to be misaligned with steering wheel splines just enough to bind it. i buttoned it back up until i could consult with you guys and now the slop is gone but when i turn the ignition switch on the horn blows. disconnected hot wire at horn and awaiting advice. thank you, thank you.
flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,734 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
I've had that happen with my stock wheel & horn. I think I eventually had to replace the metal horn contact plate, but first check the wire to the horn button and see if the insulation is damaged - quick wrap with electrical tape might solve it.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
You tightened the wheel and the horn shorted. The wire that connects to the horn button is a ground wire. Sounds like the wire has grounded to the momo adapter. That may be why the wheel was left loose.
Lo-Fi Version | Time is now: 26th June 2024 - 06:39 AM |
