mrholland2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California ![]() |
Hi,
I have two questions: 1. How do I safely remove the back trunk hinges with the torsiony springs so I don't screw something up or hurt me. 2. I'm switching stuff from one body to another. . trying to remove the engine compartment lid release cable, but on the old car, there is an attached tube and the new body doesn't have one. So, is there a different kind of self-contained cable I can use as the release cable? Thanks Sean |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
1.) Requires a tool to release the end of the torsion bar from the roller.
2.) Somebody cut the tube out then. A choke pull cable assembly can be installed to release the engine hatch. |
injunmort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States ![]() |
I use a deep socket on an extention bar to release the torsion bars from the rollers.
r_towle |
Deep 10 mm socket on a 6 inch extension as the handle.
Put it over the end of the torsion spring, gently push down, get it off the roller and let it all the way up, it just about touches the body when released. Trunk lid must be removed. Best to have the engine lid removed also. Hold it firm, it's under pressure all the way to the end....which is way into that pocket area that holds the hinge. For the second one, some brake line fabricated to the right shape and tacked into place will do the trick. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:48 AM |
