Is the yellow wire on my starter in the correct spot? |
Steve |
Jun 1 2014, 09:54 PM
914 Guru Group: Members Posts: 5,623 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
76-914 |
Jun 1 2014, 10:26 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,521 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Can't tell much from that pic. Which ever one of the small spades makes the starter engage when you jump it across the large pole w/ a screw driver.
rgolia |
Jun 2 2014, 09:59 AM
GeoJoe Group: Members Posts: 705 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
yes that is correct
malcolm2 |
Jun 2 2014, 10:06 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
It is tuff to see since you have the boot on the battery post, but it does look correct. If you test it, make sure you are in neutral. Touch a screw driver to the post that the battery cable is on and the blade the yellow wire is on. That will activate the starter and the solenoid. You will hear the tell tale cranking sound. If the key is ON, it should start or at least fire.
If you touch the screw driver to the 2 large posts the starter will turn, but the sol will not engage. |
Steve |
Jun 2 2014, 11:51 PM
Thanks everyone for the help!!
Jeffs9146 |
Jun 3 2014, 06:01 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Thanks everyone for the help!! Here is a photo someone posted in the past! Attached image(s) |
Lo-Fi Version | Time is now: 30th June 2024 - 07:38 PM |
