Won't Crank, What are the possible issues? |
Ken6432 |
Jun 9 2014, 02:23 PM
Newbie Group: Members Posts: 39 Joined: 10-March 14 From: Indianapolis, IN Member No.: 17,098 Region Association: None |
I have a '74 with a 2.2 L with dual carbs. I just swapped the engine and used all of the same accessories as the last (running) engine. Now that everything is bolted up, I am trying to crank the engine and nothing is happening. Here's what I have:
Both large wires connected to connector 30 Single wire connected to connector 50 Fully charged battery Voltage reading from connector 30 to the vehicle floorboard When I turn the key, I hear the electric fuel pump kick on then get one click and that is all. I tried connecting a remote starter switch between 30 and the other large connector and got nothing. I also connected the remote starter switch between 30 and 50 and got nothing. Any suggestions on where to look next? Is the starter bad? It worked fine before. Thanks, Ken |
stugray |
Jun 9 2014, 02:36 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
1 check battery for charge
2 smack the starter with a wrench while trying to crank (not kidding) |
Ken6432 |
Jun 9 2014, 02:46 PM
Thanks. I'll give the "smack it with a wrench" a try. I think the battery is fully charged.
Ken |
toolguy |
Jun 9 2014, 02:48 PM
Senior Member Group: Members Posts: 1,273 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Ground strap at transmission
Chris H. |
Jun 9 2014, 02:49 PM
Senior Member Group: Members Posts: 4,043 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yep check the ground strap. Make sure it's reconnected tightly at the trans and the underside of the rear trunk.
Ken6432 |
Jun 9 2014, 02:59 PM
The ground strap appears to be tight. Since I am getting voltage between the 30 terminal and the floor of the car, would that mean that the grounding strap is connected well enough?
toolguy |
Jun 9 2014, 03:41 PM
Begin here. . assuming you have the starter connected correctly,
do you have 12v on the large yellow wire at the starter with the key in the start position. . If yes. . then bad starter or solenoid or ground. . If no, test yellow back to the ign switch looking for an open. . . Hint You've got a 74 right. . still have the seat belt logic switch under the drivers seat ?? another test: If you short the yellow lead on the solenoid to the battery cable terminal lead, the starter should crank. . make sure car is out of gear first ps testing with a meter is not the same as knowing the trans strap is a good ground. . since you're measuring battery12v to a known frame ground [ the floor], you did not test the ground strap as a path in this case. . . . see if you have 12v using the trans as a ground source?? the starter needs an absolutely solid ground connection to operate. . |
Rand |
Jun 9 2014, 04:38 PM
You can spend a lot of time troubleshooting and checking connections, or you can cut to the chase quickly. Use the screwdriver trick at the starter and rule out half the steps in one second.
SKL1 |
Jun 24 2014, 06:22 PM
Senior Member Group: Members Posts: 1,625 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Similiar issue with my '73. Put in a new stronger starter like I have in my '71 which works great in that car.
12v cable from battery and cable from alternator on same post on starter-correct? Starter does not have label (50 or 30 etc). Smaller wire with blade connector. Turn key- nothing happens. Tried the screwdriver by-pass, just a couple sparks... Put on old starter for hell of it and same thing... Already have NEW ground strap from tranny to body... I HATE electrical issues!! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
Dtjaden |
Jun 24 2014, 06:29 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
Also check the other ground path - the battery to the car body.
SKL1 |
Jun 24 2014, 07:25 PM
New ground strap there too. Hell, everything is pretty much new during restoration including new JWest fuse panel... I'm sure there is some loose wire or wires somewhere...
Lo-Fi Version | Time is now: 26th September 2024 - 12:06 PM |
