Stock Exhaust Install, Stock Exhaust Install |
Highland |
Jul 2 2014, 05:22 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I'm having trouble installing my exhaust to the left head. Here are some facts of my situation.
1) Heads are rebuilt with new studs. 2) Right exhaust went on fine. So yes, I am using the correct side. 3) The exhaust and these heads were ever paired up in the past. 4) Everything is 2.0 L stock. 5) Visually the exhaust ears look off by less than a millimeter. Thanks for any help. If the ears are bent can I bend them back or just file the inside? |
JawjaPorsche |
Jul 2 2014, 06:16 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
My guy heated up the ears and bent mine slightly to fit.
VaccaRabite |
Jul 2 2014, 07:29 PM
En Garde! Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
If it were me, I'd hog out the bolt hole that is off by a MM.
Zach |
stugray |
Jul 2 2014, 11:46 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have seen step studs that have a bend in them.
I think they are the forged type threads not the die cut. So they wouldnt line up unless you clocked them correctly. I had to watch them very carefully as I was threading them in to figure it out. |
Lo-Fi Version | Time is now: 25th June 2024 - 09:27 PM |
