bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Is there any sound or heat reduction advantage to lining the bottom of the top?
I've seen what looked original a perlon carpet glue on. Probably for styling though. What about a spray on roofing insulation material? What have you used? All thoughts welcome. |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
It's easy enough to glue some person to the top and see if it makes a difference. I have one top and one without the liner, and I can't tell any difference between the two.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Found some heat and sound padding at pep boys. Looks very similar to stock. Very thick. 24sq/ft for $40
Attached image(s) ![]() ![]() ![]() ![]() |
ripper911 |
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States ![]() |
It's easy enough to glue some person to the top and see if it makes a difference. (IMG:style_emoticons/default/blink.gif) |
larryg |
Newbie ![]() Group: Members Posts: 37 Joined: 5-February 14 From: portland oregon Member No.: 16,961 Region Association: None ![]() |
Is there any sound or heat reduction advantage to lining the bottom of the top? I've seen what looked original a perlon carpet glue on. Probably for styling though. What about a spray on roofing insulation material? What have you used? All thoughts welcome. I went a little crazy with the dynamat. Put it in the doors, on the firewall, and finally on the targa top under the new liner. Combination of dynamat and new rubber on the top make a noticeable difference in the noise. Only regret about the top is that it's considerably heavier now. |
ehokana |
Member ![]() ![]() Group: Members Posts: 99 Joined: 11-August 13 From: SoCal Member No.: 16,237 Region Association: None ![]() |
It's easy enough to glue some person to the top and see if it makes a difference. (IMG:style_emoticons/default/lol-2.gif) For some reason I figured that would be somewhat difficult- but hey, I'm no expert on these cars |
ripper911 |
Any person will do, but smaller ones are easier to manage.
bandjoey |
I'll try the Pep boys route first. If that doesn't work I'll see if my neighbor will volunteer for some glue tests. (IMG:style_emoticons/default/biggrin.gif)
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
I'm leaving it off. The top is heavy enough as it is. Plus, I live in Paradise.
Lo-Fi Version | Time is now: 26th June 2024 - 06:28 AM |
