bob |
Member ![]() ![]() Group: Members Posts: 146 Joined: 8-January 03 From: Va. Member No.: 109 Region Association: None ![]() ![]() |
I have a 1969 911 S aluminum pressure plate part number 901 116 009 00. I need the thinner clutch disc to use it.
anyone? -bob |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
koozy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None ![]() |
Call Rich Bontempi at High Performance House in Redwood City, CA. He has one. Tell him Mike Koozmin sent ya.
650 364-6234 |
koozy |
You can also make shims. A common way around this issue. I've done it. Works just fine. What size engine are you planning to use this on? That pressure plate will easily be overwhelmed with an increase in torque from the original specs. Just something to keep in mind.
bob |
Thanks for the tip... I thought about shims and if I cant find a disc, I'll try that. (Rich didn't have any left)
anyone else? for whatever it's worth, it's a 2.2 motor. -bob |
Lo-Fi Version | Time is now: 20th June 2024 - 11:56 PM |
