cn2800 |
Member ![]() ![]() Group: Members Posts: 119 Joined: 11-August 14 From: Amarillo, Texas Member No.: 17,766 Region Association: None ![]() |
I'd like to give a hearty greeting to all my new friends here.
My father purchased a new silver 1.7 in the summer of 1973, and owned it until the early nineties. I was trolling Craigslist Friday, and ran across a '73 for sale. She's in rough shape from a front-end collision, but remarkably rust-free (for a 914) and otherwise pretty complete. The seller wanted a few hundred for the car, so I figured, "what the heck?", bought it and had it flatbedded to the shop this evening. I'll give a lengthier intro with more photos tomorrow, but for tonight, I have a question - The following photos are from this car's engine bay. Is this a 2-liter engine? The badging is for a 1.7, but from the information/descriptions I can find, this appears to be a 2.0. I've not had a chance to vacuum the dust to find if the engine # is between the case and the oil fill tube (2.0) or on the upper right rear (1.7). Also, the ECU is not located next to the battery, but in the front-middle of the firewall. Many Thanks, Carl ![]() ![]() |
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Looks like a 2.0 breather! Take a look at the point where the intakes bolt on to heads. If they are 3 bolt intakes then you have 2.0 heads.
Check the engine number and compare to the numbers listed here to be sure. |
cn2800 |
Spent lunch cleaning and eyeballing the engine. It has a 2.0 engine number by the oil tube:
![]() So it's a '73 with 1.7 badging, housing either a '73 or '74 2.0 motor. VIN: ![]() Was it common to swap in the larger engine? Gang, if this were a Cadillac, I'd already have all the answers - this project is 180 degrees from anything I've worked on in the past. Thanks for any additional info you can provide. I will take and post photos of the whole vehicle this evening. Carl |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,824 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Welcome. Looks like you have plenty of cleaning to do! I'll suggest you post your city, so the folks in Your neighborhood can offer to help. Some us actually like to get our hands dirty and it looks like you have a virgin car that hasn't been touched in quite a few years.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Since the 2.0 bolts up to a 1.7 without any hassles (assuming enough of the FI and such was still attached to it) the upgrade is relatively common.
Sounds like you're off to a good start! --DD |
Mblizzard |
That's a pretty sweet score! I swapped out the 1.7 in my 71 with a 2.0 but kep the 1.7 badge to make people wonder!
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
It is a early 73. I may or may not have some odd parts on it. Since it was made before Jan 1 73 it may not have guard beams in the doors. It may have the early window rollers, not the later style.
cn2800 |
Ok - during our first full day together, I bought us some beer and we got to know each other. I have photos of the whole car from yesterday after she was dropped off. However, it felt it would be inconsiderate to publicize pictures of the car when she was so filthy.
The following photos were taken today after a vacuuming and quick wipe-down. Engine compartment without air cleaner in place: ![]() ![]() ![]() Below the battery tray: ![]() |
cn2800 |
Interior shots. The seats are a bit rough, but the door panels and lower portions of the dash are in excellent condition (anything that wouldn't naturally be in the shade is pretty cooked - typical of the area).
![]() ![]() ![]() ![]() 435] ![]() Attached image(s) ![]() |
cn2800 |
Exterior photos. As you move down through these shots, you might want to be sure that the children and any adults of weak constitution are out of the room. Here's where you will see why the car was just a few hundred dollars.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() There is a '74 parts car included in the deal. I have not yet picked that one up. The body shell is good on that car. |
cn2800 |
Trunks - Front shows cut-outs for the dealer AC system condenser as well as the remaining drier bottle, hoses, and wiring (compressor, brackets, and interior parts were included with the car - none of the front trunk mounted parts were there).
![]() Anything here that looks like rust is just West Texas dust: ![]() This is a crummy shot, but the dark spots under the rear deck lid seem to be where holes were filled in. I'm guessing a long gone luggage rack? ![]() Other than the battery tray, this is the worst rust I've encountered. It's just surface rust. ![]() |
cn2800 |
Labels and rocker panels:
The various tags/labels - ![]() ![]() ![]() ![]() Behind the passenger's and driver's seat, under the carpet- ![]() ![]() Passenger side behind the decor rocker panel (this is the longitudinal?). The hoses are the remaining refrigerant lines for the AC system. ![]() ![]() ![]() |
cn2800 |
I'm in Amarillo, Texas. The house is some six minutes North of I-40, and 13 minutes from the Amarillo International Airport (gateway to Europe and the Orient - in case you have a layover...)
I'll take the driver's side decor rocker off tomorrow and see what's under there. So far, I am astonished at the lack of rust (based on Dad's car and what I've been reading). I hope that the 'solidness' of this car outweighs the front-end collision damage. You may all rest easy knowing that I'll not start chopping the dead fender off until I have had several in-person consults with either some experts from here or other Porsche/unit body experts from in town. This car is too lovely to hack up! Disassembly photos and updates may become sparse in the next couple of weeks. I'd like to leave the car as complete as possible until Mom and Dad get home from vacation. I'd like for them to be able to sit in a relatively complete car (for sentimental reasons) before the real work gets underway. Again, I'd like to thank you all for the information you've deposited on this site, and your continued interest and encouragement regarding this 914 '1.85'! Carl |
Lo-Fi Version | Time is now: 25th June 2024 - 09:41 PM |
