02loftsmoor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region ![]() ![]() |
I did I locate oll the oil galley pluggs ?? (IMG:style_emoticons/default/confused24.gif)
And how do you guys get your cases so clean?? (IMG:style_emoticons/default/idea.gif) need some help here guys,, Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() |
JStroud |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California ![]() |
oil galleys
The link above is when I did mine, maybe it will help, galley plugs start at post 15 if it doesn't take you right there. Was having trouble verifying from your pictures. good luck, Jeff |
malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
IIRC Jake's kit had the 5 big ones in it. The plugs are on either end of the engine. I don't remember any on the sides. Type 4 store oil galley plug link your #1, 3, 4, 9 and 10.
Word is that the little ones don't fail. Anyone else remember that? Soap and water, degreaser, a stiff brush and a strong spray and the case will shine right up, til you put it back in the car.... (IMG:style_emoticons/default/piratenanner.gif) |
02loftsmoor |
glad i asked, i missed a whole bunch,, I converted the link to a PDF for referance
02loftsmoor |
I will take any and all tips on this build, never built a VW engine.
malcolm2 |
I will take any and all tips on this build, never built a VW engine. I rebuilt one in the 80's using a Haynes manual and then again now using Haynes, Climer, etc... and Jake's DVD and this forum. (IMG:style_emoticons/default/aktion035.gif) So it can be done, just go slow, read and measure more than twice. |
Lo-Fi Version | Time is now: 25th June 2024 - 09:48 PM |
