Cuda911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California ![]() |
What's the point of the little plastic plugs in the trunk bed?
There are three of them under the foam liner. (well actually, I only have two... anyone know where I can find one? I know they are not needed, but I want to make this car as "complete" as possible). Why did Porsche bother designing these holes and then design plugs for them? Drain holes in case I want to use the trunk as a kiddy pool? Also, one is a bit smaller than the other two, and appears to be threaded. Have a plug you can spare? Thanks! . Attached image(s) ![]() |
dlkawashima |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California ![]() |
I don't know about the two larger holes, but the smaller, threaded hole is for mounting the spare tire in the rear trunk. And you are correct that normally all three holes are capped.
(IMG:http://www.914world.com/bbs2/uploads/post-5765-1146748481.jpg) |
sbsix |
only the lead dog enjoys a change in scenery... ![]() ![]() Group: Members Posts: 452 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California ![]() |
I'm looking for the small plug, as well. Anyone? Bruce Stone?
peteyd |
Senior Member ![]() ![]() ![]() Group: Members Posts: 708 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada ![]() |
The plugs are for air to escape while closing the trunk. Otherwise with the seal it would be air tight and you would not be able to close it as easy.
Cuda911 |
So with the threaded one, the idea is that I can choose whether I want the spare in the front or the rear?
Back to the other two holes/plugs: Anyone else know? Pete, an interesting guess, but it can't possibly be correct. First of all, the plugs are meant to be left in place. By your theory, I would need to remove them to easily close the trunk. Second of all, they are below the foam pad and the carpet, which would block air flow through them. |
dlkawashima |
RFoulds |
Green Teen 66 ![]() ![]() ![]() Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region ![]() ![]() |
My guess is drains., the front trunk has them as well, and it also has 2 holes with tubes that drain out.
Cuda911 |
Nope, not drains. They are on a raised support member. A drain would be on the lowest surface.
So, still leaves this mystery open. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
That's where Fritz was supposed to squirt the rust proofing.
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
My guess is to keep junk or moisture from falling into the cross member cavity. The holes were probably needed for the venting of the welding gasses during assembly of the chassis? Or to allow paint-primer to get into the cavity? This is just a guess.
Cuda911 |
Hmmm... the holes seem too "finished" (ex: rolled lip) for anything like that, to me. Seems like something along those lines would have just been a punched hole. And, certainly not designed for a plastic plug.
Most mysterious, indeed. |
ripper911 |
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States ![]() |
Now that you have observed them, their purpose has changed.
mobymutt |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada ![]() |
I would guess that the holes were meant for locating pins during manufacture.
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
Porsche added them so that Herb Kunststoff could build a small business in Hamburg manufacturing these little plastic plugs. (IMG:style_emoticons/default/coffee.gif)
Cuda911 |
(IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif)
Now, to the most serious of issues: Anyone got a plug they don't need (the larger size)? My car will never be complete until I find one! |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
walterolin |
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States ![]() |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Now that you have observed them, their purpose has changed. schrodinger is dead and the cat has 9 lives. Open & close the trunk lid 8 more times.... That actually was really funny (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:42 PM |
