How does one remove the door contact switch? |
doug_b_928 |
Aug 25 2014, 08:07 PM
Senior Member Group: Members Posts: 694 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
It must be something simple, but it's escaping me. How does one remove the door contact switch? I've removed the screw and used needle nose pliers to disconnect the wires from the switch (I couldn't see much so I also now don't know what wire goes where on the switch). It doesn't look like there's any way for it to feed through the hole from outside to inside, and it will almost come out from the inside to the outside but it feels like if I pull any harder it will break. What's the trick?
partwerks |
Aug 25 2014, 09:36 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
It must be something simple, but it's escaping me. How does one remove the door contact switch? I've removed the screw and used needle nose pliers to disconnect the wires from the switch (I couldn't see much so I also now don't know what wire goes where on the switch). It doesn't look like there's any way for it to feed through the hole from outside to inside, and it will almost come out from the inside to the outside but it feels like if I pull any harder it will break. What's the trick? I haven't looked at it lately, but does it come out from the area where the speaker grille is, or do you have to position it correctly, to take it out from the front side maybe? |
cn2800 |
Aug 25 2014, 10:27 PM
Member Group: Members Posts: 119 Joined: 11-August 14 From: Amarillo, Texas Member No.: 17,766 Region Association: None |
cn2800 |
Aug 25 2014, 10:41 PM
Apologies, that photo is a bit misleading - the switches are installed with the screws inboard.
You'll notice that the inward corner of the panel-bound portion of the switch is chamfered to facilitate rotation for installation/removal. |
doug_b_928 |
Aug 26 2014, 07:29 AM
That did it (IMG:style_emoticons/default/smile.gif) . Thanks so much for taking the time to help.
Lo-Fi Version | Time is now: 25th June 2024 - 11:10 PM |
