Wheels and Flares To The Max, Will 9's Fit? |
Lucky9146 |
Sep 22 2014, 11:08 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,666 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Recently purchased 74 abandoned 914-6 conversion project with Professionally fitted factory PN steel flares. Much work is done including conversion to 5 lug. Car currently has Fuchs 16" 7's & 8's. Car is in Build & have 3.0 close to ready to go in so has never been driven by me. Plan to autocross. Hope to move 8's to the front. My question is will Fuchs 9's fit the rear with the flares? Would I need to do something to make it happen? Does anyone know anybody who has actually done this? I'm a new member so appreciate any help. Thanks!!
JoeSharp |
Sep 22 2014, 11:56 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
I believe so as I have 8's under my narow body car. You will probably need spacers.
Lucky9146 |
Sep 23 2014, 12:07 AM
Thanks Joe, I am considering buying 9's.
SirAndy |
Sep 23 2014, 01:04 AM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You need to get the right offset for them to fit as 9" is a tight fit. Not all 9" wheels are made the same.
(IMG:style_emoticons/default/smile.gif) Unfortunately, i don't recall the correct offset for those wheels ... PS: (IMG:style_emoticons/default/welcome.png) |
914dave |
Sep 23 2014, 04:39 AM
914 Addict Group: Members Posts: 720 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
I have 9 x 17 Lindsey wheels with the 911 turbo 9 x 16 Fuchs offset and they fit with 245 tires. They actually have more inboard offset than the 911 8 x 16 Fuchs. So you can space them to get the optimum fit. There are wheel offset charts posted on Pelican that are helpful with the comparison. There are others here that have run the 9 x 16s, hopefully they will chime in. Good Luck Here's a pic of the Lindseys mounted.
Mike Bellis |
Sep 23 2014, 07:41 AM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I have 9x16 under my flared car. 9x16 ATEV, early offset, ET15 8x16 with 3/4" spacer (1986 944 Turbo early offset, ET23 I think) |
madmax914 |
Sep 23 2014, 08:41 AM
Member Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
Here's a chart that shows the offset and back spacing.
http://members.rennlist.com/911pcars/wheelwts.html |
effutuo101 |
Sep 23 2014, 11:46 AM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
where are you at? I have a 9x17 and 8x17 you can test fit depending on where you are at.
d914 |
Sep 23 2014, 02:05 PM
Advanced Member Group: Members Posts: 2,345 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
I believe the et has to be a 15, et15.
had 9's on my old car |
ConeDodger |
Sep 23 2014, 02:26 PM
Apex killer! Group: Members Posts: 23,853 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I have custom built 8.5"X16" Weidman Wheel built Fuchs on my car. Harvey knows the exact offset needed to fill the factory flare completely as there isn't a bit of room left.
Also, your factory flares have a different flange than the reproduction flares. The reproduction has a 1/2" or so of flange that has to be trimmed if you are going to get real wide... Side view from above... Original Customs installed the flares and there isn't a bit of room left in the rear. Attached image(s) |
Lucky9146 |
Sep 23 2014, 03:07 PM
Harvey Weidman |
Sep 23 2014, 03:29 PM
Newbie Group: Members Posts: 18 Joined: 3-April 13 From: Oroville, CA Member No.: 15,731 Region Association: None |
Lucky,
When going from the 8X16 to the 9X16 Fuchs added the 1" width by adding (about) 3/8 to the outside and 5/8 to the inside. They USUALLY fit but there is some difference on where some fenders are welded on (IMG:style_emoticons/default/smile.gif) I always check before purchase. The big question isn't weather they will fit or not but have you looked at the available tires? DOT-C are mostly the specs....not too many "streetable" tires.... 225/50s will work but they are pretty stretched out. And you know 9X16s look just like 8X16s from the outside so you'll be losing the stagger look. You may find the tire selection, looks, price and fit to out weigh wider wheel impulse. HTH H |
rick 918-S |
Sep 23 2014, 04:14 PM
Hey nice rack! -Celette Group: Members Posts: 20,826 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
16 X 8 and 16 X 9's 255's on the rear. They are phat!
sixnotfour |
Sep 23 2014, 04:24 PM
914 Wizard Group: Members Posts: 10,681 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I have 15x9's with old 245/50-15's , one side fit ,one side needed alot of work..Factory Flares, installed by AA.
Attached thumbnail(s) Attached image(s) |
eric9144 |
Sep 23 2014, 10:26 PM
Advanced Member Group: Members Posts: 2,756 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Welcome, I'm right up the hill near Mt Woodson, work in Poway (IMG:style_emoticons/default/beerchug.gif) |
EdwardBlume |
Sep 23 2014, 10:42 PM
I want 16 x 8s and 9s for the ABM! (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif)
Madswede |
Sep 23 2014, 10:58 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
I also have Fuchs 16x9 in the rear under flares. They are AA repro flares, though.
chads74 |
Sep 24 2014, 07:40 AM
Member Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States |
Elliot Cannon |
Sep 24 2014, 07:49 AM
Back spacing is about 5 1/2 inches. 9X17
Attached image(s) |
effutuo101 |
Sep 24 2014, 09:04 AM
PM me, you are more than welcome to swing by and give mine a test fit!
Btw. Welcome and this thread is worthless with out pictures! |
Lo-Fi Version | Time is now: 27th December 2024 - 12:16 AM |
