Cuda911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California ![]() |
A couple weeks ago, I changed out my dash light bulbs for LEDs. When I was done, I noticed that the high beam light on the dash wasn't working.
But, I also noticed that the driver's side high beam wasn't working (passenger side is fine), so I figured the high beam filament was burned out, and that was why the dash high beam light wasn't coming on. Today I replaced the driver's side bulb, but the high beam still doesn't work on driver's side. I'm guessing these two issues are somehow related. Suggestions from you guys? Thanks!! ('74 1.8, in case that makes a difference) |
siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
fuse?
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
fuse #1 powers the left high beam and the high beam indicator http://www.pelicanparts.com/914/parts/Elec...lectric_74B.jpg
messix |
bird board electric diagrams, look up the part that doesn't work in the description and find the track and follow the schematic http://www.pelicanparts.com/914/914_electrical_diagrams.htm
Cuda911 |
fuse #1 powers the left high beam and the high beam indicator http://www.pelicanparts.com/914/parts/Elec...lectric_74B.jpg Thanks! Wow, odd to me that only one high beam would be on the fuse. Here's something odd fuse-wise... a few days ago, I parked my car. When I came back to it a few minutes later, I found that three of the fuses had jumped right out of the fuse box! One was on the driver's seat, and two were beneath it. Are these fuses made from Mexican jumping beans? |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,517 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
You wear a size 11 or larger shoe? You probably kicked them out.
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
Keep a close eye on your left foot when you get in, or out, of the car.
Cuda911 |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I've kicked out fuses before. If you don't have one, I suggest purchasing one of the fuse covers. The electrics on this car are 40+ years old and suck at best. No need to make them more unreliable. (IMG:style_emoticons/default/smile.gif)
sb914 |
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,322 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California ![]() ![]() |
I'm always kicking my fuse box. The first place I look when I have a electrical problem
HalfMoon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region ![]() |
I had the exact same problem not long ago. Take the fuse out and emory cloth each end and the clips that hold it in.
Fixed my problem. |
Lo-Fi Version | Time is now: 24th June 2024 - 06:59 AM |
