> How to kill rust, Restoration discussion
GermermanCarGuy
post Nov 10 2014, 08:18 PM
GermanCarGuy
Okay World. Not sure if this question had been posed yet, and if it was, it’s probably worth restating due to the many newer products on the market. So here goes. (IMG:style_emoticons/default/dry.gif)
What are the better, best and best-est anti-rust treatment solutions/solvents available for preparation of our many smaller parts and components?
I’m looking to get educated on options other than the grinding wheel/rattle-can approach (i.e., soaking solutions and/or paint applications). Body’s going to media blasting but the other parts are mine to mess with.
Replies(1 - 13)
Mike Bellis
post Nov 10 2014, 08:29 PM
Resident Electrician
A Crucible...
Melt it down. That will kill it for sure... (IMG:style_emoticons/default/happy11.gif)
post Nov 10 2014, 08:40 PM
Resident German
QUOTE(Mike Bellis @ Nov 10 2014, 06:29 PM) *
A Crucible... Melt it down. That will kill it for sure... (IMG:style_emoticons/default/happy11.gif)
Not true.
One of the problems VW was facing in the mid '70s was rust from within the brand new panels after they switched to using recycled steel.
Apparently, traces of rust can survive the melt down.
altitude411
post Nov 10 2014, 08:46 PM
I drove my 6 into a tree
Holy water (water w/a hole in it) nogetwet.com (IMG:style_emoticons/default/FERG.gif)
914werke
post Nov 10 2014, 09:17 PM
There is reason it has the nickname "Cancer" ~
veekry9
post Nov 10 2014, 11:52 PM
OldMember
Group: Retired Members
https://www.youtube.com/watch?v=NKZv14-K71g
http://www.instructables.com/id/Electrolyt...oval-aka-Magic/
https://www.google.ca/#q=corrosion+removal+electrolytic
https://www.youtube.com/results?search_quer...al+electrolytic
veekry9
post Nov 11 2014, 12:01 AM
OldMember
https://www.youtube.com/watch?v=v7TnNEBy3tI
Amazing!
veekry9
post Nov 11 2014, 12:05 AM
OldMember
https://www.youtube.com/watch?v=4QrLCGVVjzg
Anyone try this?
https://www.youtube.com/watch?v=Q8Xo43sfLgY
D-cells.
http://www.swdinc.com/BlackOxideBasics.html
https://www.youtube.com/watch?v=K5lvnTKcMeE
more
https://www.youtube.com/watch?v=AyMrhkQ4zj0
Jett
post Nov 11 2014, 12:15 AM
Try evapo rust, Eco friendly and works
QUOTE(GermermanCarGuy @ Nov 10 2014, 06:18 PM) *
r_towle
post Nov 11 2014, 07:06 AM
Custom Member
Phosphoric acid
veekry9
post Nov 11 2014, 09:13 AM
OldMember
http://www.evapo-rust.com/
Virtually identical to Cling-Surface product from the '70s.
No fuss,painless.
veekry9
post Nov 11 2014, 09:50 AM
OldMember
http://www.oldengine.org/members/orrin/rustdemo.htm
A thorough explanation.
GermermanCarGuy
post Nov 11 2014, 11:00 AM
GermanCarGuy
Exactly what I needed to learn. Leaning towards the evapo-rust product for parts to be painted. Sounds like I can use it in my garage without gaseous byproducts. Once done, reuse or dispose. Either way, the dogs won't be hurt.
Really like the electrolysis process for the unpainted, bare metal parts (i.e., hinges, springs, linkages, etc.). After cleaning, home plating sound like the next logical step. Just might make an experiment out if it. (IMG:style_emoticons/default/stirthepot.gif)
Okay, so once treated, the next question is "How do you keep rust away?" I understand metal etching primers like POR 15 and Rust-Oleum are popular choices, and adhesion sealer applied prior to undercoating or "Rhino" lining. Are these the only options? (IMG:style_emoticons/default/idea.gif)
post Nov 11 2014, 11:23 AM
Resident German
QUOTE(GermermanCarGuy @ Nov 11 2014, 09:00 AM) *
The problem with any of the surface linings is that when they crack (not if, but when) they will trap moisture underneath and actually promote rust.
I can't tell you how many times i have poked right through what looked like solid metal covered in undercoating, POR15 or rhino lining ...
- Lo-Fi Version Time is now: 26th December 2024 - 01:53 AM
