DougC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 ![]() |
Got a line on a Tach from a '71 911T...will that be what I need?
Doug C |
BigD9146gt |
OCD member ![]() ![]() Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand ![]() |
What motor, fuel supply (injection/carbs) do you have?????
DougC |
Don't have a motor yet, let alone a fuel supply (LOL), basically trying to collect all the Six conversion pieces while waiting for a good deal on an engine to pop up. You know of one? Will the engine determine which tach I need? Thanks ..
Doug C |
BigD9146gt |
It really depends on the engine your going with... All the 911T with carbs and the 914-6 are the same. The impulse signal is the same. It gets tricky when you get to the CIS engines in ~'73/'74. Then i cannot say with certenty. But, with the 3.2 i know gets its signal from the motronic brain. I'd wait till you get the motor, cause a used tach isn't all that expensive. North Hollywood Speedo does conversions for tachs, so if you want a vintage tach with a 3.2 inner workings, your gonna have to folk over the dough...
Hope that helps, Don. |
DougC |
Thanks for the advice, I may go ahead and pick up the 911T tach anyway since it's only $35 then resale it if I go with a larger engine.
Doug C |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,340 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
To get even a little more detailed:
Tachs with regular points ign thru 3 pin CD boxes Tachs with 6 pin CD box That is pretty much how they are divided up through 89' I believe. 3 pin CD's were used through the 2.7 series and the 3.0's were the first to use the 6 pin. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:11 PM |
