FS -6 turbo lower valve covers |
JStroud |
Dec 9 2014, 09:02 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Lower turbo valve covers for a -6 $160.00 shipped cont. US
tornik550 |
Dec 10 2014, 09:36 AM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
PM Sent
JStroud |
Dec 10 2014, 10:22 AM
Sold..
fixer34 |
Dec 10 2014, 01:08 PM
Senior Member Group: Members Posts: 1,102 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Lower turbo valve covers for a -6 $160.00 shipped cont. US See another thread on here about the turbo covers (sorry, I don't have the link). You WILL NOT be able to install/remove them with the engine in the car unless a little judicious machining is done. As the saying goes, 'ask me how I know...' |
tornik550 |
Dec 10 2014, 01:12 PM
Lower turbo valve covers for a -6 $160.00 shipped cont. US See another thread on here about the turbo covers (sorry, I don't have the link). You WILL NOT be able to install/remove them with the engine in the car unless a little judicious machining is done. As the saying goes, 'ask me how I know...' I purchased them and the engine is out of my car (IMG:style_emoticons/default/smile.gif) |
fixer34 |
Dec 10 2014, 01:26 PM
Lower turbo valve covers for a -6 $160.00 shipped cont. US See another thread on here about the turbo covers (sorry, I don't have the link). You WILL NOT be able to install/remove them with the engine in the car unless a little judicious machining is done. As the saying goes, 'ask me how I know...' I purchased them and the engine is out of my car (IMG:style_emoticons/default/smile.gif) Understand, but I assumed at some point in time you may want to remove them to check/adjust valves without having to drop the engine. Wasn't trying to discourage you from buying them (I have a set and am happy with them), just didn't want you getting surprised 'down the road'. |
tornik550 |
Dec 10 2014, 01:27 PM
Lower turbo valve covers for a -6 $160.00 shipped cont. US See another thread on here about the turbo covers (sorry, I don't have the link). You WILL NOT be able to install/remove them with the engine in the car unless a little judicious machining is done. As the saying goes, 'ask me how I know...' I purchased them and the engine is out of my car (IMG:style_emoticons/default/smile.gif) Understand, but I assumed at some point in time you may want to remove them to check/adjust valves without having to drop the engine. Wasn't trying to discourage you from buying them (I have a set and am happy with them), just didn't want you getting surprised 'down the road'. Gotcha- what modifications did you have to do to the covers? |
Mark Henry |
Dec 10 2014, 02:12 PM
I and many others machined all the fins down to the height of the mounting holes.
Others hand grind just the area at the trailing arm mounts. There are threads about this in the Garage. |
fixer34 |
Dec 10 2014, 07:30 PM
Lower turbo valve covers for a -6 $160.00 shipped cont. US See another thread on here about the turbo covers (sorry, I don't have the link). You WILL NOT be able to install/remove them with the engine in the car unless a little judicious machining is done. As the saying goes, 'ask me how I know...' I purchased them and the engine is out of my car (IMG:style_emoticons/default/smile.gif) Understand, but I assumed at some point in time you may want to remove them to check/adjust valves without having to drop the engine. Wasn't trying to discourage you from buying them (I have a set and am happy with them), just didn't want you getting surprised 'down the road'. Gotcha- what modifications did you have to do to the covers? You only have to remove a small section of the fins around a couple of the upper stud holes. I crawled under my car and took a couple pictures for another thread a few weeks back. I'll see if I can find either the thread, or the pictures. |
McMark |
Dec 11 2014, 07:20 AM
Here's a couple pics of the machining we've done. I usually take the minimalist approach, only removing material from where it interferes. You can also machine the whole cover down by some amount (other people know, and it's been posted).
My technique, is to install the engine without the lower valve covers installed. Then remove material until you can install the covers in the car. If they go on, they'll come off. (IMG:style_emoticons/default/wink.gif) Attached image(s) |
mepstein |
Dec 11 2014, 07:26 AM
914-6 GT in waiting Group: Members Posts: 19,326 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
5/16" reduction will usually make it work
Lo-Fi Version | Time is now: 20th June 2024 - 11:11 PM |
