Sloppy shifter, how do you finally fix this? |
brooks944 |
Dec 21 2014, 03:48 PM
Member Group: Members Posts: 248 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
I can move my shifter quite a bit in every direction. Already tried the JB weld fix a couple of times but it still gets loose. I don't have a welder, what is the next best way to fix this?
Thanks, Rick |
76-914 |
Dec 21 2014, 04:25 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,650 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Side shifter? Firewall bushings, cup washer & new bushings on side plate, and new conical screws. Shift it by the shift lever on the trans by hand to see if there is any internal slop.
JawjaPorsche |
Dec 21 2014, 04:35 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
JB Weld? So it is not your bushings but your shifter shaft is busted.
Put a WTB in classifies. Be sure to state for side or rear shifter. |
messix |
Dec 21 2014, 04:49 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
do you know any one with a wire feed welder?
you can disassemble the shift lever assembly and file/grind a couple of spots to spot weld the pivot ball on the lever, the dress the weld and reassemble. I did this and it only toke about 45min to do so. |
brooks944 |
Dec 21 2014, 05:29 PM
My car is a 75, and I am new to 914's is that a side shifter?
Thanks, Rick |
76-914 |
Dec 21 2014, 05:34 PM
Yep, that's a side shifter. If you don't want to weld a part pm Gerald Shaffer here. He's on your side of the country. Otherwise, Bdstone here but he is on the West Coast.
wndsnd |
Dec 21 2014, 05:36 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
What and where are you welding?
John |
messix |
Dec 21 2014, 05:52 PM
if you disassemble the shifter you will see the pivot ball was epoxied to the sift lever, this is where you will file/grind in to the ball and lever a flat spot or two to weld at and then dress the weld to make it blend it to the lever and ball.
rhodyguy |
Dec 21 2014, 06:23 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,198 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what's your time worth? buy a good used one, replace the 2 bushings that cradle the ball on the lever and put it in the car. 0 down time. the 2 bushings make a big difference with the shifting.
Wdunster |
Dec 23 2014, 10:15 AM
Panel beater Group: Members Posts: 172 Joined: 10-June 14 From: Monroe,nc Member No.: 17,469 Region Association: South East States |
One solution I found is to utilize an old steering shaft. Take the u-joint off to use at the shaft coming out of the firewall. It uses the same diameter shaft. You will need to cut a slot in the shaft for the sinch bolt. On the shift rod itself you will weld the spline portion onto the end after removing the joint. Once I did this my shifter was much more precise.
Attached image(s) |
GaroldShaffer |
Dec 23 2014, 07:29 PM
You bought another 914? Group: Benefactors Posts: 7,628 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Yep, that's a side shifter. If you don't want to weld a part pm Gerald Shaffer here. He's on your side of the country. Otherwise, Bdstone here but he is on the West Coast. (IMG:style_emoticons/default/bye1.gif) I sent you a PM. |
Dr Evil |
Dec 24 2014, 10:05 AM
Send me your transmission! Group: Members Posts: 23,035 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I got them, too, if Garold doesnt. I can spot weld yours, too. In OH (IMG:style_emoticons/default/smile.gif)
brooks944 |
Dec 24 2014, 11:20 AM
Thanks, replied to Garold's PM and likely to buy one of his intact shifters. As always, appreciate the advice from everyone.
Rick |
colingreene |
Dec 24 2014, 03:44 PM
Senior Member Group: Members Posts: 733 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Talk to Glen at Pelican parts and order all the new bushings also
I just did it, helped me quite a bit. |
EdwardBlume |
Dec 24 2014, 03:53 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I just installed a new firewall bushing on Dads car and it made a world of difference!
jimkelly |
Sep 25 2015, 07:39 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
how many are running this upgrade? comments? pics?
thanks jim |
Lo-Fi Version | Time is now: 5th January 2025 - 01:09 AM |
