Rocker Arm Spacer & Shim Configuration. |
tach |
Dec 28 2014, 06:25 PM
Member Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest |
Mark Henry |
Dec 28 2014, 07:29 PM
You put it what ever way gets the adjusters as centered on the valve as possible.
Around .004-.006 clearance should be good. Are those arms modified? They won't work if they haven't been. |
malcolm2 |
Dec 29 2014, 09:27 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
found a photo of mine.
might have to zoom in to see. |
michael7810 |
Dec 30 2014, 10:06 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
You will likely have to lap the solid spacers to get clearance. My rockers were tight, and I just kept lapping the spacers on fine sandpaper until the rockers were free. I've read others had to do the same.
Mark Henry |
Dec 30 2014, 10:21 AM
You will likely have to lap the solid spacers to get clearance. My rockers were tight, and I just kept lapping the spacers on fine sandpaper until the rockers were free. I've read others had to do the same. It doesn't have to be very fine, stuff like this I've used 120, but I know how to do it so you might want to double that number. Personally I've never liked aluminum spacers, I use the spacers from hydraulic engines or I make my own out of heavy steel tube. |
tach |
Dec 30 2014, 05:58 PM
Thanks for the reply's. I ended up with .0035-.004 clearance between shims and spacer.
Lo-Fi Version | Time is now: 25th June 2024 - 11:49 PM |
