strip disc vs DA sander for stripping |
got914? |
Jan 4 2015, 06:47 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
Has anyone uses both ?, ive used a DA before but not the strip disc.
scotty b |
Jan 4 2015, 07:05 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
if you're talking about the 3M type mesh discs, they both work just as well, but a box of 80 grit d/a/ is probably going to be cheaper than x# of stripping discs. The d/a/ contact area is also a slightly larger area than the mesh discs, so it goes a bit quicker. My .02
JoeDees |
Jan 4 2015, 07:13 PM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
I've used both. The stripper discs are way faster, but they wear out quickly and cost a pretty penny. They'll also destroy rubber, filler, softer plastics etc. I use both, depending on how easy places are going.
Lo-Fi Version | Time is now: 25th June 2024 - 10:55 PM |
