> 914World Classifieds Rules
> !SOLD! Modified Rear Swing Arms & Shea 5 Lug Hubs & more !SOLD!
pnewman
post Jan 8 2015, 10:29 AM
SOLD!
Used 5 lug hub conversions that were made by Eric Shea
Not used since rebuilding:
Rear Swing Arms :
Tubed
Also reinforced at pivot / tube joint
Towing loops welded on
grease fittings installed
(in case you choose to use bushings that would require lube.)
Towing loops welded for J hooks
Powder coated
Cadmium plated:
rear pivots / shafts
bearing retainers , bolts and washers
10 Studs
2 Brake Clips
I am throwing in a set of Poly Graphite bushings
(One of the bushings had some filing work done to one end.
I don't think that it will effect the performance but thought it only fair to mention.)
SOLD!
Pete
Replies(1 - 5)
pnewman
post Jan 8 2015, 10:53 AM
I outlined the reinforcement plates at the pivot (in red) to clarify.
barefoot
post Jan 8 2015, 11:52 AM
Nice looking A-arms, but I always wondered if the rather skinny double row bearing was the weak link in rear rigidity. I would have thought that two single row bearings spaced several inches apart would have been a better design.
lapsinc
post Jan 8 2015, 02:54 PM
Sent pm
pete000
post Jan 8 2015, 03:36 PM
Probably already gone, but PM sent...
pnewman
post Jan 10 2015, 05:51 PM
SOLD!
- Lo-Fi Version Time is now: 2nd February 2025 - 04:03 AM
