florida 914 |
Newbie ![]() Group: Members Posts: 29 Joined: 29-September 10 From: Salem, OR Member No.: 12,227 Region Association: Pacific Northwest ![]() |
Hi, folks. I have a 76 914. The steering column has a lot of play back and forth (side to side, not turning the wheel); the horn also honks when it moves around. I finally realized that there is a part missing in the assembly, a tube or sleeve of sorts. Does anyone know what I am talking about? I have another car but do not want to take it apart to take a picture of the missing part unless necessary. Thanks.
tweet |
Member ![]() ![]() Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States ![]() |
You may want to consider replacing the column assembly. It would probably be easier to swap the column than replace individual parts. Disassembling the column can be done but it is a chore.
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
It sounds like it might the the shim that slips in the cloumn shaft. It looks similar to the shim for the stock 914 shift knob.
I have some at CAMP 914. Craig at CAMP |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
There was a recent thread about this exact subject ... Click here
florida 914 |
Thanks, this is very helpful! |
pilothyer |
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States ![]() |
I had the identical problem with my '75................This was the cure, and very easy to install:
http://www.autohausaz.com/pn/92834773902 |
florida 914 |
I had the identical problem with my '75................This was the cure, and very easy to install: http://www.autohausaz.com/pn/92834773902 Thanks! |
Lo-Fi Version | Time is now: 25th June 2024 - 09:20 PM |
