chads74 |
Member ![]() ![]() Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States ![]() |
Only need one stud, but if anyone has a couple laying around I would take a few just incase. I am wanting to get my spare 1.8 running. TIA
arty914 |
Newbie ![]() Group: Members Posts: 20 Joined: 2-May 10 Member No.: 11,683 Region Association: North East States ![]() |
I needed one a year or two ago. Did a search on here and a fellow mentioned having found them at Ace Hardware. Sure enough they had them.
chads74 |
Thanks for the tip, I'll go check them out.
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Yes ACE has some, but the selection of lengths is minimal.
You might get lucky. Otherwise I cut my own from grade 8 metric all thread. If you havent found any, PM me your address and I'll send you a few. |
chads74 |
turns out there isn't an Ace close to me, so I am going to run by the local hardware store and try my luck. I'll let you know if I find something that will work. Thanks
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Let me look, I can probably fix you up with a used one.
chads74 |
That would be awesome. Thanks!
914Sixer |
Chad,
I found them. Do you need standard or 1st oversize? I have both. Just pay the postage. Thanks, Mark |
chads74 |
Sorry I didn't see earlier. Standard size, I'll pm you. Thanks!
Lo-Fi Version | Time is now: 20th June 2024 - 05:45 AM |
