> Triad Exhaust O2 Sensor Location, Picture?
BeatNavy
post Mar 17 2015, 04:38 PM
Anyone with a Triad exhaust have a picture of their O2 Sensor installed? I won't be putting the exhaust in for a couple of weeks but have some time to weld in the bung between now and then. Want to make sure I get the location right. TIA.
Replies(1 - 13)
PanelBilly
post Mar 17 2015, 04:59 PM
I do but won't be able to send a picture for a few hours
PanelBilly
post Mar 17 2015, 09:39 PM
hcdmueller
post Mar 18 2015, 01:36 AM
Region Association: England
That is exactly where I had mine welded in.
dlee6204
post Mar 18 2015, 03:17 AM
Howdy
BeatNavy
post Mar 18 2015, 03:41 AM
So slightly off center right in that collector section? I assume it's angled off center as there's otherwise something in the way, right?
Thanks, fellas.
DRPHIL914
post Mar 18 2015, 06:12 AM
Dr. Phil
QUOTE(BeatNavy @ Mar 18 2015, 05:41 AM) *
Thanks, fellas.
that is the only place it can really go due to the baffles in the collectors on each side.
Yes it will hit the transmission if its not off to the side about 45 degrees. Installed mine last year. also ran the cable up thru the center tunnel, i think thru the same opening as my speedo cable, not sure i will ahve to look.
VaccaRabite
post Mar 18 2015, 06:15 AM
En Garde!
Mine is in the same location. Be warned - its a total bitch to install it if you do so once the muffler is on the car. Doable, but a PITA. Put the O2 in first if you can.
Zach
BeatNavy
post Mar 18 2015, 06:16 AM
Very good. Thank you, sir, I believe I am all set.
BeatNavy
post Mar 18 2015, 06:17 AM
QUOTE(Vacca Rabite @ Mar 18 2015, 08:15 AM) *
Zach
Also good info. Thanks, Zach. Yes, I definitely want to weld in the bung and put the O2 ahead of time.
type47
post Mar 18 2015, 07:11 AM
Viermeister
Rod welded mine same tube but coming straight out the back. I don't have a rear valance so don't know if having a valance would interfere. I'm in FL now but if you'd like to see with O2 sensor installed, drop by and have a look.
BeatNavy
post Mar 18 2015, 07:19 AM
Hey Jim, I'll take you up on that offer (IMG:style_emoticons/default/smile.gif) When are you back? Need to get together...
pisces914
post Apr 5 2015, 07:31 PM
hey guys - i came upon this thread as i was doing some research - i have a triad exhaust and i am going to install an innovate 02 sensor & gauge, after my positive experiences tuning with an older LM-1 stand alone unit
i called innovate after reading the install instructions online - they recommend not to mount the 02 sensor directly in the muffler for a # of reasons - they do recommend to install the 02 sensor down the exhaust (on heat exchanger?) from the hottest or leanest running cylinder (maybe #3?)
any thoughts on this?
thanks, brad in seattle
DRPHIL914
post Apr 6 2015, 09:15 AM
Dr. Phil
QUOTE(pisces914 @ Apr 5 2015, 09:31 PM) *
no problems with mine located in that center section. int not actually the muffler, but is between the collectors and the muffler so should be o.k. i guess you could go and put it on the #1 pipe down toward the end if yo wanted. to
- Lo-Fi Version Time is now: 26th December 2024 - 05:28 AM
