mikedsilva |
Member ![]() ![]() Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand ![]() |
Im getting my car back together...it' new to me.
The horn works when I connect the brass ring to the shaft of the steering column.. But with the wheel and horn pad in place, it doesn't. Can someone suggest what is missing and how to connect my horn? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1427880665.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1427880665.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1427880665.3.jpg) |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
You need the plastic horn plunger. What year is your car. You have a late wheel with an early plastic wheel hub.
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
It's an early car based on the wiper switch on the dash. Needs horn contact ...
Horn Contact Part is top of page |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
SLITS |
Well, I redid the link. Hopefully it works as it is a link to Pelican Parts for the Horn Contact. Commission? |
mikedsilva |
Thank you for the replies...
I will see if I can source one of those horn buttons locally here in Australia. The car is a 1970 ex USA.. I didn't realise that my steering wheel was a later model (I am new to 914s).. will this affect the operation of the horn once I get the button? Also, is there meant to be some sort of additional wire coming through the centre of the steering wheel shaft, that is a ground? does it connect also to the plunger/button? Mike. |
mikedsilva |
Also... in the link kindly supplied, I see there are two horn buttons... which is the correct one for my aplication?
914-347-831-00 This second one is listed as 73mm 914-347-832-01-OEM |
mepstein |
You need the longer horn plunger. A late wheel will work. It's not a perfect fit but still works fine.
mikedsilva |
thanks for that... i take it the 73mm is the longer one?
mepstein |
Lo-Fi Version | Time is now: 26th June 2024 - 07:18 AM |
