arkitect |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None ![]() |
Anyone know where to get the plastic clips that hold in the rod to the fan shroud for the cooling flaps? Pelican Parts?
Also couple of other parts that go on the shroud, there is a rubber seal that goes on top of the oil cooler and rubber elbow that connects to the alternator. Dave ![]() Attached thumbnail(s) ![]() |
arkitect |
hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
check 914 rubber , pelican parts, think i got the alternator boot from a vw web site, can't remember the name of it. |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Your ball peen will be on jackstands if you don't start a rust prevention plan soon. (IMG:style_emoticons/default/biggrin.gif)
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Busdepot.com carries the alt boot
Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
Busdepot.com carries the alt boot (IMG:style_emoticons/default/agree.gif) $15 http://www.busdepot.com/021903655b |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Bus depot or bughaus for the alt boot. I have a used oil cooler seal if you can't find one. Might have the clips for cooling flaps too.
arkitect |
Bus depot or bughaus for the alt boot. I have a used oil cooler seal if you can't find one. Might have the clips for cooling flaps too. Curt, Thanks for the reply. If you can find the clips, what do you want for both of them? Bandjoey, I know that hammer looks pretty sad, it's been in the back 40 out in the weather for over a year. Just found it recently and started using again, still works the same. Dave |
Lo-Fi Version | Time is now: 25th June 2024 - 05:27 PM |
