> Finally some progress..., or it feels that way.
xsboost90
post Feb 22 2005, 09:36 PM
Finally after fitting, buying, fitting, dissassembling, cleaning, painting, fitting, assembly and now i have a car w/ calipers-no lines yet or mc- that has four wheels and steers w/ turbo tie rods, 911 brakes and is fully undercoated and welded up. FInallY!!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif)
Replies(1 - 4)
xsboost90
post Feb 22 2005, 09:37 PM
check out how close the caliper is to the spacer!
xsboost90
post Feb 22 2005, 09:38 PM
and the bonus, this came in the mail from germany today...will look nice up front when its done! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
ArtechnikA
post Feb 23 2005, 06:16 AM
rich herzog
QUOTE (xsboost90 @ Feb 22 2005, 10:37 PM)
will you be using longer studs in the hub to get full engagement of the spacer's nuts? you look to be 2-3 turns from full engagement and you'll have leverage working against you. that scares me more than a little ...
xsboost90
post Feb 23 2005, 07:14 AM
the studs go all the way to the end, but the way they are grinded off at the ends make them look funky in that picture. The nuts also have a beveled edge that sticks out past the endof the threads, making it look like the studs are farther from the end. I assure you they are completely on there. The wheel bolts are the same way. RIght to the end ofthe stud. They are even torqued to 96lbs already.
- Lo-Fi Version Time is now: 22nd December 2024 - 05:27 AM
