> FI Intake Runner Gasket Install, cooling tin in the way?
Bruce Allert
post Mar 4 2005, 12:42 AM
Hellions asleep
After re-installing the cooling tin (after painting) I put the phenloic intake gasket on the head to see how the fit was going to be. The tin has 3 tabs that extend under the gasket. Is the gasket supposed to go onto the head first then the tin? When I took the intakes off, the gaskets came with them. I figure the gasket should go over the tin but wouldn't that be cause for a vacuum leak??? Here's the tabs on the tin I'm speaking of.
........b
Replies(1 - 12)
scotty914
post Mar 4 2005, 12:57 AM
suby torque rules
either trim the tin or the gasket, i personally would shave the gasket not that pretty tin (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif)
Bruce Allert
post Mar 4 2005, 01:01 AM
Hellions asleep
Thanks Scott on both answers! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) The tin is under the gasket about an 1/8". As for the tin, I spent two hours cleaning & painting it. Next time I do that it'll be outta the car! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
......b
Rhodes71/914
post Mar 4 2005, 01:02 AM
Glacier
I thought the same thing when I was test fitting mine, but under the tabs on the tin there is a space on the head that the tab get pushed into when the gasket is in place.
Bruce Allert
post Mar 4 2005, 01:05 AM
Hellions asleep
Thanks Sean... that's good news. I learned quite a bit today & yesterday taking this tin off for the first time. There's some cool stuff under there! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
.......b
Rhodes71/914
post Mar 4 2005, 01:24 AM
Glacier
Yeah it kinda sucks you gotta cover it all up.
MattR
post Mar 4 2005, 01:28 AM
What years is that tin? I didnt notice that when I put my engine together. Maybe I overlooked it?
Bruce Allert
post Mar 4 2005, 09:28 AM
Hellions asleep
QUOTE (MattR @ Mar 4 2005, 12:28 AM)
It's a '74.
There wasn't too much crap on the cooling fins. Brinkmans brake cleaner took care of that along with the oil cooler. I did have to scrub the bright center area of the engine tho... geeze, what a bunch of built up stuff!
Glad I installed the drivers side tin first (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) that was one hard sumbitch to get back in without beat'n the shit outta the new paint. I'll get it finished today & post a pic.
........b
Dave_Darling
post Mar 4 2005, 01:29 PM
914 Idiot
I don't recall the left and right arrowed spots on the engine tin interfering with the gasket on my car. The middle arrow would, if there were not a recess in the cylinder head for the tin to slide into.
--DD
Bruce Allert
post Mar 4 2005, 03:53 PM
Hellions asleep
I found the left arrow'd tab did not interfere but the right one sure did. I cliped it and it fits fine.
Not sure how the normal way is to re-install the runners... I installed the plenum then pushed the runners into it. T'was a beotch to say the least. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Had to use a wee bit O' lube!!! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
.......b
StratPlayer
post Feb 26 2006, 11:37 PM
StratPlayer
When installing these gaskets do you use any gasket sealer on those, or installed without any sealer?
MattR
post Feb 26 2006, 11:42 PM
QUOTE (StratPlayer @ Feb 26 2006, 09:37 PM)
No sealer is necessary.
Rand
post Feb 26 2006, 11:52 PM
Cross Member
I used silicone spray on the inside of the intake runner seals between the plenum and runners. Popped together nice and easy. Did not use any sealant on the phenolic.
Actually, I used short pieces of radiator hose instead of the official intake runner seals. Get the right size, they fit nice and snug. And cost a fraction of the official part. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
- Lo-Fi Version Time is now: 4th January 2025 - 11:19 PM
