boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
What are all of the parts required to get the ignition switch on the dash? I am imagining /6 steering columns are hard to come by or rather pricey? Other alternatives?
Seems like the big one if the steering column area so that you can have the steering wheel lock. Also, seems like something would have to be done to cleanup the original ignition switch location on the column. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,918 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Check the classic threads, seems like there is some info there.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
All stock parts from a 911. A little bit of fab and welding. Parts are $200-300. Might also need an early steering wheel.
boxsterfan |
All stock parts from a 911. A little bit of fab and welding. Parts are $200-300. Might also need an early steering wheel. I'm planning on converting to 5-lug with full 911 front supension bits. I see that the steering rack itself is the same. Sounds like dash needs some work to hook up the column in there. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Wasn't the 72 /6 ignition the same as the /4?
Just asking... |
theleschyouknow |
Senior Member ![]() ![]() ![]() Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None ![]() |
Wasn't the 72 /6 ignition the same as the /4? Just asking... was the '72 -4 on the dash? I was under the impression all -4s were on the column? (IMG:style_emoticons/default/beerchug.gif) cjl |
mepstein |
'72, 914-6 was column mounted key. Limited to very few of the 6's. Earlier was dash mounted.
mepstein |
Wasn't the 72 /6 ignition the same as the /4? Just asking... was the '72 -4 on the dash? I was under the impression all -4s were on the column? (IMG:style_emoticons/default/beerchug.gif) cjl All 4's are on the column |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,289 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,107 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
so the column key would be correct for a 72' tribute car?
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,333 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
See : http://www.914world.com/bbs2/index.php?sho...=100179&hl=
This might help (IMG:style_emoticons/default/smile.gif) Attached image(s) ![]() ![]() |
rhodyguy |
check out post #7 in that linked thread.
boxsterfan |
I actually just miss the ignition on the dash like the previous Porsches I have owned. Seems like a worthwhile mod to me. Reminder: My car is currently half torn apart in the garage as it undergoes a rest-mod (I'm not building a concourse car) with tasteful mods.
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
All stock parts from a 911. A little bit of fab and welding. Parts are $200-300. Might also need an early steering wheel. Would you get the column assembly,clamshell,indicator/wiper switches and ignition switch for that ? considering you have to pay P car tax then 911 tax (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) . I don't know ? but for coolness factor yes but the cost would be up there. |
dug |
Member ![]() ![]() Group: Members Posts: 182 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California ![]() |
I believe I have all the parts to do this conversion. I will put together a list of what I have, including a 914-6 column. I can use the funds for a worthy cause.
cheers, dug |
mepstein |
All stock parts from a 911. A little bit of fab and welding. Parts are $200-300. Might also need an early steering wheel. Would you get the column assembly,clamshell,indicator/wiper switches and ignition switch for that ? considering you have to pay P car tax then 911 tax (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) . I don't know ? but for coolness factor yes but the cost would be up there. Here's what I purchased for $250. Didn't pay tax (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) ![]() |
Mark Henry |
boxsterfan |
so the column key would be correct for a 72' tribute car? That was what I'm getting at, if it is a conversion car, 72-up, the key on the column is still technically correct for a /6. It's not a conversion car. Just looking at the mod. I am converting to a Getty 911 style dash. Motor will be a /4 still (2270 with ITB's). |
boxsterfan |
naro914 |
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States ![]() |
I just got a 911 ignition switch, drilled a hole (though I think I just used one that was there), took out the column switch and welded it shut. It uses the stock 914 everything else (switches and all) I don't have a steering column lock, and its the 'wrong' ignition in the dash, but thats OK with me....I was never looking for authenticity...
Lo-Fi Version | Time is now: 24th June 2024 - 11:48 PM |
