> BUILD-OFF CHALLENGE: Michigan Build, Garland, Never ending project, 8/2023 reinstalling headlamp housings
Garland
post Sep 30 2015, 10:39 PM
Restoration Fanatic
The start:
2016 Build-Off
Here I go!
I purchased the car on eBay in 1999 site unseen, and only two polorid's in the post. Looked great, sitting in a empty dusty old garage. I ask lots of questions, original paint? Factory new looking wheels? History, on and on.
He couldn't tell me anything about the car, his buddy owned it and he new nothing.
Singed over ownership 6 mts ago. He did say looks like a great car, and knows it was fast. Says 2.0 on it. 400 miles away, a buddy with a flat bed, it was worth the risk. Price was right.
On arrival, I'm on it, all over the car. Long story short the thrill is gone!
Repaint in somebody's garage, 50 footer, or a polorid. Rear end hit, hard, car pushed into something damaged the left front. Right front damage, not to bad.
Engine runs on 2 cylinders, yet it is a 2.0, with carbs. Must have been the reason for the FIRE in the engine bay. One head is trashed from the fire, and theirs nothing else to talk about, except the A/C system they must have got on eBay and hacked into the car.
(Key words: eBay, "was" fast, Polorid, and risk)
I swapped in a 1.7 and a tail shift 2.0 exchangers with triad exhaust. 1971 complete interior (had one). Plus just about every other trim part. Polished the paint, cleaned up the wheels, and I drove it. Now it's time to fix It.
MICHIGAN BUILD
(Short monthly update posts) @ Contest Link
1973 Red 1.7
5 Major Tasks to complete during the Challenge:
1. Replace back half of rear trunk floor. (Rusted, rear ended, poorly patched)
& Replace entire rear body panel, and Bumper. (Rear ended, poorly repaired)
& Patch in 1/2 left front fender. (Poorly repaired)
2. Delete headlamp doors, modify hood, and relocate headlamps.
3. Install 4 steel flares, and modify all valances. 5 lug, and wheel tire package.
4. Build up, and replace engine.
Installed now:
With:
1.7 914 Engine balanced
260 x 396 Cam .006
96mm Big Bore kit
Mallory Unlite Distributor 14004
Weber 40 DCNF (w/ very short intakes)
Air jet 1.80 Main 1.25
2.0 L exhaust
Work in progress replacement.
5. Major interior renew.
Still need to finish the engine, and start it. Purchased here from a member a few years ago.
I have a 2nd 914 that I'm also working on, and been a owner of many since the 70's. I do all my own work. My enjoyment time.
9 Pages V  1 2 3 > »
Replies(1 - 19)
Garland
post Sep 30 2015, 11:42 PM
Restoration Fanatic
I replaced the hoods with ones of better quality, reason for primer. Got started on this last weekend.
Remove the rear trunk have, and tail panel.
Look at the amount of weld they used and lots of filler. No to mention the extra layer of sheet metal.
The tail was cut in hafe and re welded back, In turn the the panel holding the tail lights was flat across. No curve to meet the trunk.
Used air punch from H.F. Worked very well. Lots of welds to do.
the tail and hood are from a green 70 (in the data base)
Cairo94507
post Oct 1 2015, 06:59 AM
Michael
Nice looking job. You will have a nice 914 when you get her done. Keep up the good work. (IMG:style_emoticons/default/biggrin.gif)
Garland
post Oct 2 2015, 09:54 PM
Restoration Fanatic
Thanks Michael.
Well I rough trimmed and fitted the tail section, and worked on removing the glue for the carpeting. What a pain!
Garland
post Oct 3 2015, 09:19 AM
Restoration Fanatic
Started cutting for the headlamps, and as I was putting this on the scrap pile I thought.....
This should be the teener torch.
914forme
post Oct 3 2015, 05:24 PM
Relocating the headlights (IMG:style_emoticons/default/popcorn[1].gif) wondering what you have in mind.
DRPHIL914
post Oct 3 2015, 05:34 PM
Dr. Phil
I think that snow picture should be considered for the calendar.
stevegm
post Oct 3 2015, 05:39 PM
QUOTE(Philip W. @ Oct 3 2015, 07:34 PM) *
(IMG:style_emoticons/default/agree.gif) If you have a high resolution version (8" by 10", at around 300 DPI) you should submit it - http://www.914world.com/bbs2/index.php?showtopic=265151
Garland
post Oct 4 2015, 08:02 AM
Restoration Fanatic
The headlamps are going to a challenge in it self. I have a few ideas, fixed in the bumper opening, and reshape the bumper lower edge for room, and along the top edge of the valance. Also was looking into retractable, also in the bumper. More to come on this.
One other idea I have that's not listed in my build list. That is to rake the roof, a bit. What do you think? And have seen drastic rake of the roof, but I thinking just a bit like this. Just chop the roll bar 2 inches, adjust the body work to meet the targa top, and Windows. Not a cut and paste job. No metal roof.
Garland
post Oct 4 2015, 08:07 AM
Restoration Fanatic
Scraped all carpet, glue and some seam sealer. .
Garland
post Oct 4 2015, 11:25 AM
Restoration Fanatic
Then paint remover, and a rinse
Garland
post Oct 4 2015, 12:41 PM
Restoration Fanatic
My 73 build off challenge car. "Michigan Build"
Sep 2015 now the Build off car.
And At the Midwest classic in 2004
My inspirations for this build.
The one I sold, 27 years ago.
My 914 back in "80's sold in "88 Started as a club racer, then back to driver. Owned this one for ten or more years.
The garage were I did all the work.
Converted back to road car
Club racing it in Oakland Michigan 1970-80
The black car we have all seen.
Mike1981
post Oct 9 2015, 06:51 PM
Nice Work John
I always thought your Red 1.7 looked great to me.
Admire your skills and work ethic
Mike
trojanhorsepower
post Oct 12 2015, 07:35 PM
John,
Who made your rear trunk floor patch panel?
Garland
post Oct 13 2015, 11:07 PM
Restoration Fanatic
Right here:
Great products! They have molds. Family owned company.
trojanhorsepower
post Oct 14 2015, 09:48 AM
Humm. I have the same one, but mine does not have that lip over the cross brace. It just runs out straight. Did you fold it over to make the flange for the spot welds? Did you drill and weld in a nut in the cross brace, or just go with out it?
Garland
post Oct 14 2015, 04:35 PM
Restoration Fanatic
I bent the lip, and made the flange. I did not add the nut. Just be sure to line it up tight, before you decide where to bend. And that the small center cap fits the width.
dakotaewing
post Oct 14 2015, 04:52 PM
You might consider striping all the paint off the inside of the rear panel, and priming most of it prior to welding that piece in...
it will be easier to treat the small areas of rust with the panel out as well -
Looking good!!
Garland
post Oct 19 2015, 09:31 PM
Restoration Fanatic
QUOTE(dakotaewing @ Oct 14 2015, 04:52 PM) *
Looking good!!
Thank you,
Update:
Weld primer only where needed, expensive stuff.
Printing found on the factor metal.
Very little experience at welding, but improving.
(IMG:style_emoticons/default/welder.gif)
About 250 welds.
Garland
post Oct 21 2015, 05:42 PM
Restoration Fanatic
Finished up the rear early steel bumper. Needed to close up the holes from where some PO drilled to mount tits on a early bumper. I also used a wheel to knock down the weld, disc to removed 80% more, then a flapper disc to finish. Buy the time I get to the fenders, I think I will feel confident that they will turn out nice.
9 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 2nd April 2025 - 07:29 PM
