Cal |
Senior Member ![]() ![]() ![]() Group: Members Posts: 615 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States ![]() |
Question.....I'd like to replace the Bursch exhaust that the PO put on my '74 2.0L with the stock Dansk exhaust that's shown in this photo. Are the two strap hangers in the center of the exhaust standard.....I don't remember seeing these on other stock exhausts. Does the stock Dansk bolt directly to after market SSI heat exchangers? What's needed to install the exhaust and how difficult is it?
Attached image(s) ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,921 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Those straps are for a 911 exhaust system. Some one must have used a 911 muffler hanger instead of the 914 one. Dansk should bolt right up to SS exhaust.
Cal |
Those straps are for a 911 exhaust system. Some one must have used a 911 muffler hanger instead of the 914 one. Dansk should bolt right up to SS exhaust. I thought that looked familiar.....I actually like the way it looks. Anyone know how it's mounted? I found a photo of how a stock unit mounts. Attached thumbnail(s) ![]() |
914Sixer |
My opinion is that it is NOT a good idea. The shape of the 914 mount is a triangle. It provides stability to the heat exchanger. Straps only support the muffler.
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
This muffler is SIMPLE to install. I did it in the dark, (because I was so excited to cure my exhaust leaks) that I did it after wifey fell asleep.
I only put the straps on for looks, the muffler is bolted on correctly to the factory hanger. I have a different GT banana /6 muffler all ready for my 911 conversion, and these came with it. I tried the straps on my new 2.0 Dansk banana just for looks and fun. It is NOT at all being held on by these clamps, but I thought they looked cool. The muffler has the notches on it for these so I went for it. I actually straightened the muffler out a bit after I took this picture yesterday too, it looks a bit off kilter here. |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,858 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
I also like the GT muffler strap kit.
Larmo63 |
Lawrence has good taste. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 01:37 PM |
