Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
just bought a set of 911 hubs last week
shoulda bought these instead (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) these allow you to use 986 or 996 rotors Attached image(s) ![]() |
dakotaewing |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region ![]() ![]() |
You know Jeroen, that's just not very nice....
Posting pictures and not giving any details.... Thom |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
i concur! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) ebay? use the same 911 bearings? what year to what year will they fit? |
Jeroen |
they use stock 911 bearings and wheelstuds
waiting for a price... |
Jeroen |
mueller, if I buy one, can you copy them for cheap?
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
Looks like 993 stuff
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
my god... it's so totally insane..
You would just end up adding useless weight... you guys are gearheads, who can't leave it alone!! Lighter units would be better, just ask mikez. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) All that mass is sprung, and spun.. M |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
that is how I originally wanted to do the vented rotors for the 4-lug cars......cut off the cast rotor and slide on a rotor just like that.......some of the 911 guys are already doing that using the rear rotors on the front hubs....... for that design, you wouldn't even have to buy one.....heck, your standard 911 hubs will do the same thing, the only difference should be is the location of the face, did they move it inboard to compensate for the thickness of the rotor hub?? |
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
yeah, but they look cool (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
TimT |
You chuck the 911 hub in a lathe and trim so the disc fits, then you center the caliper over the disc via shims.
This is one of the great benefits of radial mounted calipers, is that you can easily adjust them in two planes. versus the lug mount calipers ability to only be adjusted in one plane (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) burp |
Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Mine look like the same rotors above (996TT) and they're mounted to the outside of '77 911 hubs. I took the hubs and rotors to my machinist and told him to make the rotor a press fit. He had to remove about .030 off the hub to make it fit. Attached image(s) ![]() |
Jeroen |
even better!!!
thanks for the info |
Lo-Fi Version | Time is now: 26th June 2024 - 08:34 AM |
