Clutch tube repair, Tips |
BeemerSteve |
Jan 15 2016, 11:10 AM
Member Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest |
I have the daunting job of clearing out my interior and cutting my tunnel open to repair the clutch tube. Does anyone have tips on doing this job? Do the fuel lines need to be taken out? Humm.......maybe I should if they're still plastic.
I appreciate all your wisdom as I'm trying to gain some on my own. Thanks!! Steve |
TheCabinetmaker |
Jan 15 2016, 11:43 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Tube can be accessed and sometimes repaired through the shifter opening without cutting the tunnel. It's possible to remove shifter with out disturbing the rod
Spoke |
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Here's a write-up of how I repaired my clutch tube. It was basically free of any supporting material when I started the repair.
Clutch Tube Repair |
Bruce Hinds |
Jan 15 2016, 12:05 PM
V-8 madness Group: Members Posts: 734 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
The right way of course is to cut it open and weld it up and make a big project out of it. On the other hand, you can make a nice little bracket to put in under the shifter to hold it in place. Not the best repair but it works.
Sorry no pics, I did it too many years ago. |
sean_v8_914 |
Jan 15 2016, 12:06 PM
remove fuel lines at engine or at firewall (depends on what you have there after 40 years of creative mechanics)
drain tank then and plug lines with 8mm bolt. add 1qt water to tank (no, its not going to harn anything) remove shift rod and shifter |
sean_v8_914 |
Jan 15 2016, 12:13 PM
there are 3 attachement points
all must be addressed if firewall is ripped 1. forward of shifter hole about 4 inches on the left wall of the tunnel 2. about 10 inches forward of fire wall. this bracket hangs from teh top of the tunnel 3. where the clutch tube exits the firewall i go in from the bottom. its cleaner that way Attached thumbnail(s) |
sean_v8_914 |
Jan 15 2016, 12:29 PM
it the tube is loose but the firewall is still OK this means the middle bracket is still intact. the front bracket is the first to break.
in this case i weld a 1"x1" L-bracket to the tube. this minor solution is quick . you only have to remove the shifter and dont need to mess with fuel ines. i still stuff a wet rag against them just in case did i mention remove clutch cable... Attached thumbnail(s) |
sean_v8_914 |
Jan 15 2016, 12:33 PM
before we get carried away, lets see some photos of the firewall
sean_v8_914 |
Jan 15 2016, 12:35 PM
next time yall cut access panels, clean the metal on both sides of the cut line prior to cutting. easier than after its cut. only cut 3 sides. just score the 4th side and it will bend clean and return to original position to weld iit closed
JeffBowlsby |
Jan 15 2016, 01:26 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
No need to remove the fuel lines, just wrap them in a wet towel when welding.
So which of the three attachments is broken? If its just the front one then no need to cut anything, just a couple plug welds to hold the guide tube to the tunnel sidewall: Attached image(s) |
BeemerSteve |
Jan 15 2016, 03:00 PM
Wow!! Thanks you guys! Now I have lots to chew on after I clear the interior stuff out of the way.
I'm having difficulty with posting pictures but will try to figure that out soon. Thanks again, much appreciated! |
76-914 |
Jan 15 2016, 03:53 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,613 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
next time yall cut access panels, clean the metal on both sides of the cut line prior to cutting. easier than after its cut. only cut 3 sides. just score the 4th side and it will bend clean and return to original position to weld iit closed I like that approach, Sean. (IMG:style_emoticons/default/thumb3d.gif) |
cary |
Jan 15 2016, 08:57 PM
next time yall cut access panels, clean the metal on both sides of the cut line prior to cutting. easier than after its cut. only cut 3 sides. just score the 4th side and it will bend clean and return to original position to weld iit closed I like that approach, Sean. (IMG:style_emoticons/default/thumb3d.gif) I was thinking the same thing. Nice work. (IMG:style_emoticons/default/welder.gif) |
PancakePorsche |
Jan 15 2016, 09:10 PM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Mine too broke and was good at the firewall. I made a clamshell bracket for the front which was installed using one bolt and did not require any cutting of tunnel. All was done thru shifter opening. Still working good.
Good reason to to properly lube and maintain your clutch cable to prevent this from occurring in the first place. A dry cable housing causes excessive load on the tube. |
jsaum |
Jan 15 2016, 09:59 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
There is a good write up in the classic threads on the tube repair with pictures and on the Pelican site tech info section they have some good pictures of the center tunnel. I did mine had to replace the entire tube it wasn't that bad.
Jsaum |
BeemerSteve |
Jan 16 2016, 01:36 AM
Mine too broke and was good at the firewall. I made a clamshell bracket for the front which was installed using one bolt and did not require any cutting of tunnel. All was done thru shifter opening. Still working good. Good reason to to properly lube and maintain your clutch cable to prevent this from occurring in the first place. A dry cable housing causes excessive load on the tube. Did you by chance take any pictures? I'd be curious to see how you did it. |
sean_v8_914 |
Jan 16 2016, 02:10 AM
i have had to replace the entire tube on a few
this is currently to most common 914 weld job for 2015 i think they will all break . the l bracket under the shifter is so quick and easy. i can do it with the clutch cable in place but many have welded the inner cable to the tube (hearse ) |
Dr Evil |
Jan 16 2016, 04:29 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I have fixed them with a sheet metal screw and a conduit clamp as a temp......that lasted over 10yrs without an issue.
BeemerSteve |
Jan 16 2016, 05:31 PM
I have fixed them with a sheet metal screw and a conduit clamp as a temp......that lasted over 10yrs without an issue. Thanks for confirming that approach because I thought about that idea as well. Since this car has lots-o-rust and the mechanical components will be the donor I will only need a temp fix for this anyway. Most all parts will be moved over to a 1973 2.0 tub that has very little if any rust as it sat in a garage awaiting a failed v8 swap. The tub only has 60k mikes on and sat for almost 30 years. I will be contacting you for a 901 rebuild this year too. Thanks! |
barefoot |
Jan 17 2016, 08:45 AM
Senior Member Group: Members Posts: 1,318 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Lo-Fi Version | Time is now: 28th September 2024 - 07:06 AM |
