SKL1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,612 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest ![]() ![]() |
Thinking of putting a side view mirror on pass side of my '73. If I remember correctly when havin the panel off, the nuts are welded in place on the inside for the screws aren't they? Even though it would pain me to do it, you could drill from the inside through those to create the holes?
Can you just turn the mirror around to use a spare mirror from the driver's side, or it a different part number for right (pass) side? I may chicken out when it comes to drilling the holes though (IMG:style_emoticons/default/blink.gif) |
Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
Thinking of putting a side view mirror on pass side of my '73. If I remember correctly when havin the panel off, the nuts are welded in place on the inside for the screws aren't they? Even though it would pain me to do it, you could drill from the inside through those to create the holes? Can you just turn the mirror around to use a spare mirror from the driver's side, or it a different part number for right (pass) side? I may chicken out when it comes to drilling the holes though (IMG:style_emoticons/default/blink.gif) You are correct on all points. The mirror can be flipped. Some debate as to whether there was a factory passenger mirror part number. I suppose the nuts were there for right hand drive cars... |
Mike Fitton |
Senior Member ![]() ![]() ![]() Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest ![]() ![]() |
I use my passenger side mirror all the time while driving you will not regret it.
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
Thinking of putting a side view mirror on pass side of my '73. If I remember correctly when havin the panel off, the nuts are welded in place on the inside for the screws aren't they? Even though it would pain me to do it, you could drill from the inside through those to create the holes? Can you just turn the mirror around to use a spare mirror from the driver's side, or it a different part number for right (pass) side? I may chicken out when it comes to drilling the holes though (IMG:style_emoticons/default/blink.gif) You are correct on all points. The mirror can be flipped. Some debate as to whether there was a factory passenger mirror part number. I suppose the nuts were there for right hand drive cars... No debate at all in fact! They were required equipment to have mirrors on both sides on cars in Sweden back when new `69-76, & a few other countries too (& RHD ones, as Kansas said), plus a factory or dealer supplied option on any 914 when new. In fact have a brand new Porsche part pass. side mirror - which is slightly convex for pass. side (I bought 2 new L & R a couple of years ago), & AFAIK they're still available from Porsche new .... at a Porsche price of course. It is also orrect that - you can also flip a flat driver's side one, if you're on a budget, but want the added safety of the p-side mirror visibility. Correct on the nuts welded to the underside of the outer door skins on both driver & passenger doors. Wrong on the drill from the inside - you'll need to carefully measure & find them on the outside & drill IN to door skin - otherwise you'll have the steel skin push-up to the outside, which you then have to flatten & cause more skin damage, or else they'll make the flat gasket under the mirror base not sit flat. After drilling, I'd recco using some Wurth or Eastwood zinc rich primer on the bare metal, then a touch-up with enamel/urethane in your body color to prevent rust at the holes, but don't get it into the nut threads. Not a bad addition with today's traffic & crazy drivers texting/talking! Plus nobody will worry about correct Porsche 914 "flag mirrors" on both sides at any PCA concours - & many out here in CA have them both sides. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
BeemerSteve |
Member ![]() ![]() Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest ![]() |
Also, before you start to drill from the outside put a piece of masking tape where you are going to drill measure to mark it then use the center punch and drill. Remember, measure, measure, measure then when you feel comfortable with it....drill away!
This keeps the drill bit centered and helps it from walking causing paint chaff. Rip the tape off and voila!! |
dlkawashima |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California ![]() |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
I just did my black car. It takes ten minutes. The nuts are exactly where they are on the driver's side. It's not that big of a deal.
Measure, mark it and drill. From the outside. |
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
As far as I know there was never a right hand drive of the 914 model....only left hand drive.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I disagree about drilling from the inside. One of 2 ways. Run an 1/8" quality bit thru the nut with a small amount of pressure. You don't need to "stand on" a sharp bit and it will therefore not push the metal up. Then use a cheap Needle or Rat Tail file from the top to open up the hole.
Or, use a short piece of tubing or bushing stock placed in the same nut then run a bit thru the same size as your stock I.D. This centers your bit dead on. Then move to the outside and step drill to the proper size. Don't use cheap freaking bits and throw the dull ones in the trash. Low speed isn't necessary on thin metal but lube always helps. Plain old paraffin wax is great especially when drilling upside down. (IMG:style_emoticons/default/beerchug.gif) |
SKL1 |
Great advice but my hand will probably start shaking as it gets close to that nearly new bahia red paint!! (IMG:style_emoticons/default/smile.gif)
Darren C |
Member ![]() ![]() Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England ![]() |
Use the internal punch method to mark the exact positioning, drill from outside in ever increasing drill sizes 2.5mm up to 6mm to check you’re not drilling off centre and cutting into the captive thread. (If you go off centre you have time to recover it at small drill diameter using a swiss rat tail file to get you back on track).
(IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1454575232.1.jpg) |
Tbrown4x4 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 705 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None ![]() ![]() |
Thinking of putting a side view mirror on pass side of my '73. If I remember correctly when havin the panel off, the nuts are welded in place on the inside for the screws aren't they? Even though it would pain me to do it, you could drill from the inside through those to create the holes? Can you just turn the mirror around to use a spare mirror from the driver's side, or it a different part number for right (pass) side? I may chicken out when it comes to drilling the holes though (IMG:style_emoticons/default/blink.gif) You are correct on all points. The mirror can be flipped. Some debate as to whether there was a factory passenger mirror part number. I suppose the nuts were there for right hand drive cars... Like raynekat said: I don't believe there were ever RHD 914's. Also, the part number for the convex RH mirror is (was?) 914 731 040 10. Straight out of the parts katalog. LH mirror was 914 731 039 10. The real convex mirror is supposedly hard to find. |
tomrev |
Member ![]() ![]() Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None ![]() |
Can you access the inner nuts without pulling out the window? I ask, as I have't pulled the panel yet to look, but have been thinking of adding the mirror too, as was considering being lazy, and doing a measure/locate from the outside.
Larmo63 |
The cars were manufactured with the capture nuts in the door for a reason.
I use the right hand mirror constantly and I think the car looks better with two mirrors. |
Darren C |
Tomrev,
Yes, remove door trim and roll up window, you can reach inside and around to feel the captive nuts. No need to take out the glass. |
tomrev |
McMark |
I tend to just turn my head. So I'll be the voice of dissent and say the car looks better with one mirror. (IMG:style_emoticons/default/laugh.gif)
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Don't use cheap freaking bits and throw the dull ones in the trash. Low speed isn't necessary on thin metal but lube always helps. Plain old paraffin wax is great especially when drilling upside down. (IMG:style_emoticons/default/beerchug.gif) Throw the cheap ones away when they get dull, but it doesn't take any time to sharpen a quality bit. I use a 6 inch bench sanding disc and wear magnifiers for my older eyes. In college I had electives, so I took metal shop in the engineering department. First thing they had us do is to file a perfect cube to .001 out of bar stock. They also showed us how to sharpen bits. Eventually we got to the Bridgeport and Southbend and Heliarc. It is a bit scary to find the nuts behind the metal. And also easier than one thinks in the end. Because it is sort of like a magic trick I suggest shooting the holes with a .22 and a hand mirror. Preferably with an ace of spades taped over the hole. |
worn |
I tend to just turn my head. So I'll be the voice of dissent and say the car looks better with one mirror. (IMG:style_emoticons/default/laugh.gif) Doesn't everyone do a head check mirror or not? You coming on the trip south btw? |
Darren C |
"I tend to just turn my head"
Not so easy in a LHD 914 driving on the leftside in the UK when all you see in the drivers door mirror is the sidewalk :-) Much much safer to have the passenger mirror I can tell you. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:09 PM |
