Exaust Stud Help, I think couple studs need to be relpaced |
Eric Taylor |
Mar 19 2005, 08:27 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
Alright so here is the deal, i've got what sounds like an exhaust leak on my car, and I know that when you take the exhaust off about 4 studs come with it. In the past however they have all tightened right back in no problem, however one now is rather loose, and causing a minor leak. What would you guys do? Oversized? Helicoil? New head (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) ? The car is so close to being a driver, just gota take care of the minor shit:).
Eric |
xsboost90 |
Mar 19 2005, 09:45 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
you could retap to a larger stud size and put in a stud w/ a larger thread on the head side...you know, two sizes, one stud. or i guess you could helicoil it or do as they do in the ghetto and jb weld it.
john rogers |
Mar 20 2005, 12:00 AM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I would pull the heat exchangers and look at the studs and the holes carefully. The studs with the larger head side threads work well, but remember you'll be doing it laying on your back with the car on stands and not much room to work. It would be a very good time to chech all of them? The studs are slightly easier to do than the inserts. Good luck
Lo-Fi Version | Time is now: 25th June 2024 - 11:11 PM |
