> Front control arm, Why no gasket here?
Olympic 914
post Feb 8 2016, 12:14 PM
Started installing some of my front end parts and when putting on the control arm I noticed a gap. checked the manual and it doesn't show anything going in here. there are gaskets that go under the torsion arm adjusters but what sense is that if there is a large gap here that water and debris can get into???
I have these gaskets
but the manual clearly shows that they go here...
I am tempted to just put them in the gap shown in the first picture and buy a second set to go under the torsion bar adjusters.
I checked that I didn't put the ends on wrong when I put in the elephant rubber bushings on. I don't think they would fit the other way anyhow, the front of the control arm would be to far forward.
I put am putting 911 struts on but these parts all are the original 914 stuff.
What say you???
Replies(1 - 7)
Olympic 914
post Feb 8 2016, 02:00 PM
I haven't had anyone come up with a good answer yet. so instead of buying gaskets I thought I would make up a couple.
So not to be outdone by Series9 skillful use of his new lathe. I found a likely piece of gasket stock ( Pool noodle ) and made these.
little big but they should squish down.
fits good.
post Feb 8 2016, 02:16 PM
Resident German
(IMG:style_emoticons/default/thumb3d.gif)
DavidSweden
post Feb 8 2016, 02:26 PM
I made my own as well from some foam I had in the garage
Series9
post Feb 8 2016, 02:27 PM
Lesbians taste like chicken.
Yes!
(IMG:style_emoticons/default/first.gif)
r_towle
post Feb 8 2016, 05:07 PM
Custom Member
Add it to your list Joe.....
02loftsmoor
post Feb 8 2016, 06:13 PM
you just have too many toys (IMG:style_emoticons/default/smile.gif)
Olympic 914
post Feb 8 2016, 07:29 PM
Worked out good..
And its even Blue... (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 31st October 2024 - 08:19 PM
