A question for you 6 owners, 914-6 Tune up |
mr914 |
Jan 28 2003, 05:32 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
How do you do a ignition tune up on a 6? (IMG:style_emoticons/default/huh.gif)
I see the dizzy way down there in the front of the motor... Do you have to drop the engine out to get to it, or do you need to find an accomplished 12 year old? How many have modified the firewall for access? |
mskala |
Jan 28 2003, 06:49 PM
R Group: Members Posts: 1,928 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
This topic has been (IMG:style_emoticons/default/smash.gif) over on another list.
I don't think firewall changes are necessary, but some do. You will need to be able to feel for things like the nut for the clamp to adjust it, and the nut that will allow you to remove the whole thing. You will need to adjust more often if you have the original points system, which wears, but you will find that if you have the original Marelli dist (very tall cap), there are no 'points replacement' systems out there, so people switch to a Bosch equivalent ($$). I myself was lucky to find a marelli modified with a prototype optical system and I use that. Set the engine at TDC #1 and note where the rotor is pointing, to within a few degrees. Remove the nut that holds the whole distributor in and just pull it out (oh yeah, remove the wire going to the points first). The gear has very few teeth, so you won't have to work hard to get it back in the same position. Set the points gap on the bench. Once you get confident and know where things are, you could probably regap the points while it's in the car, since the exact gap is not important (CD system). Adjust dist with the engine off so the points to open right at TDC #1. Then time to 35 degrees at 6000 RPM. There are markings on the flywheel (Z1 for TDC, 35 for 35), since the pulley is impossible to see in a 914. Mark S. '70 914-6 |
Brad Roberts |
Jan 29 2003, 02:58 AM
I was going to answer, but I can see I dont need too now. Nice write up Mark.
B |
J P Stein |
Jan 29 2003, 03:54 AM
Izat' an original 6 or one you can cut holes in?
I'm a firm beliver in firewall holes but wouldn't do it to an original 6. My little rat bastard has no such restrictions. (IMG:style_emoticons/default/smile.gif) |
mr914 |
Jan 29 2003, 08:24 AM
Thank you Mark for the informative post. Being a 4 owner for 22 years, I've never fiddled with a 6....
mlindner |
Oct 27 2022, 02:02 PM
Senior Member Group: Members Posts: 1,603 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I like having the fire wall access panel. A must for replacing or tightening the fan belt. Again this is not a original six. Mark
Robarabian |
Oct 27 2022, 08:17 PM
914 A Roo Group: Members Posts: 653 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Before you remove the dizzy, get your air compressor in there to blow out any dust / dirt that may fall in when you pull it.
Also, once the pulley is at TDC, look at the flywheel and make sure of the TDC marking there before you start trying to time things. Sometimes things are not aligned the way they should be. Im considering a 123 ignition, but mine is not a factory 6 either... |
infraredcalvin |
Oct 27 2022, 08:32 PM
Distracted Member Group: Members Posts: 1,581 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Resurrected from 2003 guys…
tpines |
Oct 27 2022, 09:01 PM
Member Group: Members Posts: 77 Joined: 12-November 08 From: San Diego Member No.: 9,745 Region Association: Southern California |
I like having the fire wall access panel. A must for replacing or tightening the fan belt. Again this is not a original six. Mark Hi Mark, I think I might have already messaged you about this but if not please consider headrests for safety. Very cool car you have! Clark |
porschetub |
Oct 27 2022, 10:11 PM
Advanced Member Group: Members Posts: 4,764 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Cairo94507 |
Oct 28 2022, 06:52 AM
Michael Group: Members Posts: 10,173 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I would not cut the firewall on an original 6; we did not cut mine. (IMG:style_emoticons/default/beerchug.gif)
Steve |
Oct 28 2022, 08:34 AM
914 Guru Group: Members Posts: 5,780 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
When I had my 2.7, i installed a pertronix ignitor to replace the points. It never failed on me. My flywheel had the timing marks on it, so it was simple to rev the motor to 6k and turn the distributor to adjust. You do not need to cut the firewall to replace a fan belt or get to the distributor. I only recently cut mine, so I could replace the alternator without the dropping the engine. My current motor is a 3.2,
Jett |
Oct 28 2022, 10:00 AM
Senior Member Group: Members Posts: 1,675 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
FYI if anyone is interested… my mechanic/friend has two Marelli dists NOS in boxes… he bought them many years ago.
ClayPerrine |
Oct 28 2022, 10:21 AM
Life's been good to me so far..... Group: Admin Posts: 15,982 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Porsche Classic now sells a cap and rotor set for the Marelli Distributor in a factory six.
Pertronix now sells an electronic ignition module for the Marelli distributor for a 914-6. Clay |
fixer34 |
Oct 28 2022, 10:49 AM
Senior Member Group: Members Posts: 1,213 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
It has been many years since I set the timing on my -6, mainly because I drove it very little, but I do remember the process.
I switched to a Bosch 911T distributor 40 years ago because I was having trouble finding Marelli parts even back then. Remove air cleaner. set TDC mark on the flywheel for cylinder 1. you are using the case opening back by the transmission as you can't see the front pulley. remove distributor, replace/gap points as needed, reinstall keeping rotor lined up with mark on distributor housing. snug the retaining bolt just enough to keep the distributor from rotating on its own, but you can move it in small increments with your hand. Now the fun begins. Attach the timing light to plug wire 1, start the engine, let it warm up and have someone bring it up to 6000 rpm. this is best done by someone sitting in the driver seat. Lean over the 3 open carb stacks with the engine screaming in your ear and check the timing mark with the light. If needed, reach down with your right hand and turn the distributor ever so slightly to adjust the timing. You probably have a 50-50 chance of picking the right direction. Be aware there is a fast moving alternator belt just inches from that hand. Get the timing mark lined up with the pointer on the case and slowly tighten the retaining bolt. After each half turn, recheck the timing to make sure it hasn't moved. Once it is set, take it back to idle, reinstall the air cleaner, and take it out for a drive. |
brant |
Oct 28 2022, 12:55 PM
914 Wizard Group: Members Posts: 11,831 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
So much easier
I check it annually on the winter maintenance list Attached image(s) |
porschetub |
Oct 28 2022, 06:34 PM
So much easier I check it annually on the winter maintenance list Nice ,cut mine the same way but still tight and some danger when moving the dizzy,if you go to pointless ignition you have removed 2 adjustments and if you have a worn drive shaft bearings another problem solved . First job after getting my car running was to cut the "hole" for tuning ,no regrets but sad to do it on a real "6" . |
gulf908 |
Oct 28 2022, 11:25 PM
Member Group: Members Posts: 126 Joined: 25-December 13 From: Sydney Member No.: 16,795 Region Association: Australia and New Zealand |
every time I have significant work done,I get my mechanic to drop the motor
at the same time,I get the fan belt changed regardless of mileage and any random oil leaks fixed that were not there last time plus any other minor 'while you're there' jobs done Unless you are the mythical Sloniger 'asbestos octopus' the motor is very inconvenient to work on while in the car to me,everything else about the car is a big positive but the maintenance/working enviroment was certainly an afterthought I am totally aghast that in this day and age that anyone would cut bodywork in an original -6 to do such minor routine work - shame !! cheers Dennis (IMG:style_emoticons/default/smile.gif) |
wonkipop |
Oct 30 2022, 12:57 AM
Advanced Member Group: Members Posts: 4,670 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
factory didn't mind doing it on their own GTs!
makes it sort of semi legit? or at least common sense. personally i find it bad enough screwing around with belt adjustment on the alternator on my 4. thats when you realise the type 4 engine would be a breeze to work on in the car it was designed for....which was not a 914. (IMG:style_emoticons/default/biggrin.gif) |
jhynesrockmtn |
Oct 30 2022, 08:57 AM
Member Group: Members Posts: 426 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I dropped the motor on my GT 6 Tribute and while it was out installed a 123 distributor. Motor is original 914-6 built to 2.4. So far so good. If I keep it long term I'll consider cutting the firewall. I also dropped the motor last winter on my 1970 1.7 and installed a 123. That also went well. So far I'm a fan.
Lo-Fi Version | Time is now: 15th January 2025 - 07:05 AM |
