watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
Well, this weekend I repaired the A/C holes.
Here's the before behind the rocker panel. Attached image(s) ![]() |
watsonrx13 |
Here's the after.
watsonrx13 |
Here's the before in the front fender.
watsonrx13 |
Here's the after.
watsonrx13 |
I also cleaned and repainted my rear shocks and rear control arms.
Here's the before shocks. Attached image(s) ![]() |
watsonrx13 |
Here's the after.
watsonrx13 |
And here's a shot of the control arm.
Hope everyone else had a productive and/or enjoyable weekend. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Attached image(s) ![]() |
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
Rob,
You are inspiring me. Never thought of removing the control arm with axle/hub intact. Seems like the easiest way. Once you unbolt the outer bracket is it as simple as removing the inner large nut and pulling the whole assembly off (after cv at tranny unbolted and caliper/disc removed)? |
watsonrx13 |
Actually I removed the axle, control arm, shock, spring, caliper/disc as one unit.
Here's my web site with the steps I used. BTW, this was a suggestion by Brad.... |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,302 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
You are good.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Lookin good Rob.
Lo-Fi Version | Time is now: 25th June 2024 - 11:13 PM |
