cooler R&R, with motor in car |
machina |
Mar 21 2005, 07:12 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Got the new cooler installed. No leaks, so at least I know it was the old core that was bad.
With all my tin cut away it is easier to get in there BUT... My -10 oil lines make it impossible to get to the cooler without pulling the blower housing. My air flap is screwed down to the oil cooler duct so... I have to pull the rt side tin in order to unscrew that flap. If I drill a hole in the tin above the screwhead, I may be able to access it without taking it all apart. Didn't take that long to do the job. No way I was going to drop the motor after just getting her in again, I still would have had to pull the housing and tin off anyway. Attached image(s) |
Lo-Fi Version | Time is now: 24th June 2024 - 11:59 PM |
