> Where Dies This Wire Go?, '75 L-Jet 1.8 FI Harness
motorvated
post Feb 16 2016, 02:25 PM
It's the brown wire (with some red shrink tubing covering the cracks in the insulation) and a female spade connector on the end coming off of the fuel injection harness near the battery and ECU. You can see it just to the left of the dual relay. Is it a ground that connects to a male spade connector under the plenum?
Replies(1 - 4)
RohJay
post Feb 16 2016, 03:39 PM
It should be connected to the Ignition Coil.
motorvated
post Feb 16 2016, 03:57 PM
QUOTE(RohJay @ Feb 16 2016, 02:39 PM) *
Which side of the coil, + or -?
bigkensteele
post Feb 16 2016, 04:07 PM
Major Member
QUOTE(motorvated @ Feb 16 2016, 01:57 PM) *
Negative.
jim_hoyland
Get that VIN ?
Negative
- Lo-Fi Version Time is now: 26th December 2024 - 05:20 AM
