r_towle |
So my daughters 1999 vw cabrio had the wipers stop working while driving back to school.
So, the car is not here, it's 3 hours away, with an EE student. She has a meter, not much else. There is a trusted vw shop up the street if it come to that. She checked the fuse, it is fine. I need to get her to test the relay and I have no clue how to do that without it in my hand. Does anyone know how to test a multi speed wiper relay? Also, if we can determine with a jumper in place of the relay, if the motor works or if the motor is bad, that would be an even simpler way to test the relay.....by proving the motor works. Rich |
r_towle |
Specific question for you electrical guys.
How do you bench test this relay? Attached image(s) ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Specific question for you electrical guys. How do you bench test this relay? Not real easy ,are you sure the wiper switch on the column hasn't crapped itself,thinking 1999 convertible is a mk3 golf platform right?,the switches on these do die. A jumper cable will be #30 to 86 or 87 sorry but the memory isn't what it was (IMG:style_emoticons/default/sad.gif) . Buy a new relay it should be numbered ,not expensive but may be specific to this model golf choose carefully,best thing to try first,cheers. |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
r_towle |
Love this car (not)
Its part of two generations.... Front end and some body work is new, interior and "some" electronics are from the previous generation. Cabrio is a transition parts car.....really hard to figure out some stuff. Rich |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Rich...not the Cabrio again! (IMG:style_emoticons/default/headbang.gif)
Check VWVortex in the Cabrio section if you don't figure it out here. When I searched "wiper" there were 13 pages of posts, lots of which were titled "wipers don't work". VWVortex Not sure if this will link you all the way through. Let's find out. |
Lo-Fi Version | Time is now: 25th June 2024 - 06:05 PM |
