Mathman |
Newbie ![]() Group: Members Posts: 25 Joined: 10-May 14 From: Kansas Member No.: 17,330 Region Association: None ![]() |
Hi, all! I'm downsizing my 914 hoard, and I was curious if anyone had any need for this stuff before it goes away. I hate to toss it if someone needs it, so PLEASE make an offer. I promise that I won't be offended. I only list the prices because we're supposed to. Please note that all electrics are untested and all items are understood to be driver quality. The transmission was good when it was removed. If you have any questions, please shoot me a PM/E-mail/reply. I'll reply as soon as I am able. Payment via PayPal, shipping extra. Thanks for looking!
1 Key Blank $20 2 Heater Control Knob $5 3 HVAC Bezel $5 5 Voltage Regulators $5 each 6 Hub Covers $10 each 7 Rear Trunk Lock Spring $10 8 Fuel Lines $5 each 9 2.0 Plenum Brackets $5 for the pair 10 Fuel Injector Supports $5 each 11 2.0 Cold Start Valve Connectors $5 each 12 Belt Cover $5 each 13 2.0 Plenum $40 14 2.0 Fuel Intake Runners $20 per set 15 Starter $10 16 Alternator $25 18 Driver's Side Engine Shroud $150 for all tin 19 Various Engine Shrouds $15 per piece 21 Ignition Coils $10 each 22 Impeller Fan $50 23 More Engine Shrouds $15 per piece 24 Impeller Fan Shround $30 25 Smog Pump Pipe $20 26 Heater Pipe $15 27 Passenger Side Engine Shroud $150 for all tin 28 Defroster Vent $10 29 Leather Steering Wheel Cover $15 30 Side-Shift Transmission $150 31 Headlight Brackets $10 32 Headlight $10 33 Defroster Vent $10 34 Headlight Covers $10 35 Ashtray $15 36 Windshield Wiper Motors $10 each 38 Fuse Panel Board $10 39 Wiper/Turn Signal Stalks $5 40 Headlight Cowl $15 42 Fresh Air Vent Cover $5 43 Non-Fog Light Grille $40 46 Factory Radio $180 48 Chrome Trim $5 per piece 49 Rocker Arm Spacers $5 each 50 Windshield Wipers $5 each 51 Fresh Air Deflector $5 52 Rear View Mirror Base $5 53 Rubber Shift Boot $5 55 Turn Signal Bracket $5 56 Door Handle Bezel $10 57 Pedal Covers $5 each 58 Electric Fuel Pump $10 59 Window Crank $5 60 Trunk Bracket $5 61 Cigarette Lighter $10 (no element) 62 Seat Belt Light $5 63 Trunk Light $10 64 Steelie Lug Bolts $30 for the set 65 HVAC Cables $5 for the set Let's try this link: https://flic.kr/s/aHskwmzgof |
colingreene |
Senior Member ![]() ![]() ![]() Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California ![]() |
can you post a link to pictures that does not require a google email address
not all of us indulge in the great wide google. |
Mathman |
can you post a link to pictures that does not require a google email address not all of us indulge in the great wide google. Sorry, I thought I set it up that you didn't need to sign in. It'll be fixed shortly. Should be a Flickr link at the bottom of the page. Thanks! |
JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
Hi, all! I'm downsizing my 914 hoard, and I was curious if anyone had any need for this stuff before it goes away. I hate to toss it if someone needs it, so PLEASE make an offer. I promise that I won't be offended. I only list the prices because we're supposed to. Please note that all electrics are untested and all items are understood to be driver quality. The transmission was good when it was removed. If you have any questions, please shoot me a PM/E-mail/reply. I'll reply as soon as I am able. Payment via PayPal, shipping extra. Thanks for looking! 1 Key Blank $20 2 Heater Control Knob $5 3 HVAC Bezel $5 4 914 Trunk Emblem $15 5 Voltage Regulators $5 each 6 Hub Covers $10 each 7 Rear Trunk Lock Spring $10 8 Fuel Lines $5 each 9 2.0 Plenum Brackets $5 for the pair 10 Fuel Injector Supports $5 each 11 2.0 Cold Start Valve Connectors $5 each 12 Belt Cover $5 each 13 2.0 Plenums $40 each 14 2.0 Fuel Intake Runners $20 per set 15 Starter $10 16 Alternators $25 each 17 Alternator Brackets $5 for the pair 18 Driver's Side Engine Shroud $150 for all tin 19 Various Engine Shrouds $15 per piece 20 Flywheel $25 21 Ignition Coils $10 each 22 Impeller Fan $50 23 More Engine Shrouds $15 per piece 24 Impeller Fan Shround $30 25 Smog Pump Pipe $20 26 Heater Pipe $15 27 Passenger Side Engine Shroud $150 for all tin 28 Defroster Vent $10 29 Leather Steering Wheel Cover $15 30 Side-Shift Transmission $150 31 Headlight Brackets $10 32 Headlight $10 33 Defroster Vent $10 34 Headlight Covers $10 35 Ashtray $15 36 Windshield Wiper Motors $10 each 37 Side Marker Light $5 38 Fuse Panel Board $10 39 Wiper/Turn Signal Stalks $5 40 Headlight Cowl $15 41 Gauge Bezel $10 42 Fresh Air Vent Cover $5 43 Non-Fog Light Grille $40 44 Passenger Side Mirror $50 45 Speedometer $20 46 Factory Radio $180 47 Center Console Bracket $5 48 Chrome Trim $5 per piece 49 Rocker Arm Spacers $5 each 50 Windshield Wipers $5 each 51 Fresh Air Deflector $5 52 Rear View Mirror Base $5 53 Rubber Shift Boot $5 54 Door Vent $5 55 Turn Signal Bracket $5 56 Door Handle Bezel $10 57 Pedal Covers $5 each 58 Fuel Pumps $10 each 59 Window Crank $5 60 Trunk Bracket $5 61 Cigarette Lighter $20 62 Seat Belt Light $5 63 Trunk Light $10 64 Steelie Lug Bolts $30 for the set 65 HVAC Cables $5 for the set Pictures are available at https://drive.google.com/drive/folders/0B0p...MVdMQTB0aWJxYXc I'll take starter, an alternator and smog pump. |
Mathman |
forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
I will take the speedo, side marker lens, and guage bezel to 92651 / I can paypal to your email address payment once shipping is added in. Let me know how much to send out and thanks
(IMG:style_emoticons/default/beerchug.gif) |
TJB/914 |
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,340 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest ![]() ![]() |
Mathman,
I'll take item s #4 914 trunk emblem $15 #13 2.0 plenum $40 (best one, U-pick) I don't have Paypal, just BMO-Chase Bank Money Order + add some $ shipping if required & PM me with the total & your address if available. Thanks, Tom |
KevinGieg |
cut, weld n' wrench ![]() Group: Members Posts: 5 Joined: 8-January 15 From: Tucson Member No.: 18,309 Region Association: Southwest Region ![]() |
I'll take a fuel pump and the passenger side exterior mirror. Shipped to 94583 let me know and I can PayPal you. Thanks, Kevin
PCA7GGR |
Member ![]() ![]() Group: Members Posts: 252 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 ![]() |
PM sent on radio and steering wheel cover - thanks
Mathman |
I'll take a fuel pump and the passenger side exterior mirror. Shipped to 94583 let me know and I can PayPal you. Thanks, Kevin Just for clarification, the passenger side mirror is just the housing and gasket. There is no glass. Is that what you were expecting? |
80cap |
Member ![]() ![]() Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None ![]() |
I'll take 7, 47, and 61. The trunk spring, the center counsel and cigar lighter.
To 43011 Email me or PM. Thanks Brian |
kkid |
Member ![]() ![]() Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California ![]() |
Has anybody said speedo?
If not I am interested. Also a chrome piece that goes from the targa bar to rear fender. Thanks, kkid (IMG:style_emoticons/default/smile.gif) |
KevinGieg |
I'll take a fuel pump and the passenger side exterior mirror. Shipped to 94583 let me know and I can PayPal you. Thanks, Kevin Just for clarification, the passenger side mirror is just the housing and gasket. There is no glass. Is that what you were expecting? I was expecting that it had glass but if it's the right size mirror I forget whether it's early or late I guess I'll still take it. My mirror is five and five eights by 3 1/2 if yours is the same I'll take it. I'll also still take the fuel pump. Thanks, Kevin |
914four |
Senior Member ![]() ![]() ![]() Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States ![]() ![]() |
CaesarGz914 |
I'm new here ... Group: Members Posts: 0 Joined: 30-December 15 From: Aliso Viejo, CA Member No.: 19,501 Region Association: Southern California ![]() |
I'll take the side shift transmission, fuel pump and a passenger side window crank if you have one. Thank you,
Caesar |
sabart |
Newbie ![]() Group: Members Posts: 1 Joined: 19-October 05 From: Warsaw POLAND Member No.: 4,971 Region Association: None ![]() |
Hi ,
I'll take items #12 Belt Cover $5 each #54 Door Vent $5 # 60 Trunk Bracket $5 PM sent |
Mathman |
I'll take the side shift transmission, fuel pump and a passenger side window crank if you have one. Thank you, Caesar Caesar, ZIP code? Please note the window crank I have is technically not 914-correct. It's from a mid-70's VW, but it does fit. Do you still want it? |
forrestkhaag |
Can you send final cost to ship my items noted earlier to 91651 / I will send out funds immediately after I get the info and thanks for the offerings /
Attached thumbnail(s) ![]() |
Creamsicle New Zealand |
Member ![]() ![]() Group: Members Posts: 83 Joined: 5-February 15 From: New Zealand Member No.: 18,403 Region Association: Australia and New Zealand ![]() |
If the side mirror is available can I have it please? I understand it has no glass.
Mathman |
Lo-Fi Version | Time is now: 26th June 2024 - 04:17 AM |
